- May 27, 2006
Doc,
I was waiting on someone else to say it, I think I will concentrate on using the ones I have. Chris
Doc,
Doc,
I hope that means you're practisingSkunk: "I'm thinking more of skills, like firemaking,........."
Doc
Doc, of course! I'd never let you down. And when i am not practicing, I'm thinking about it!
Actually, I was cutting firewood yesterday, and grabbed some fine looking pieces for another bow, drill and hearth. The poplar wood is working out quite well as the hearth, it has a fairly low ignition temperature, and, as long as it's not green it tends to be quite dry. It's weight and density is along the lines of cedar.
I'm getting a good ember about 75% of the time on the first try.
After that, it's all about the tinder. Which hasn't been a real challenge as we have been in a summer-long drought.
I'm more concerned with being able to do it, with an acceptable % rate of success, under less-than-ideal conditions.
Doc,
Spooky, if you want, email me and I'll send you some instructions I worked up for JackBauer24 and Coldwood (both of whom I think are in work-to-rule mode). You can try them and see if they help.
Yes cedar works for both bow and drill.
As far as the divot goes, you only make a small indent and let the drill shape the depression for you.
Doc
Doc,
Thanks for the book recommendation I will have to see if I can track it down.
JB,
Yes, I recently, a couple of months ago, got a RAT 3 however that was probably the only knife I have bought in the last 5 years. Before the Rat, the knife I used the most was given to me by my grandfather when I was about 13. Chris
cool. I'm just giving you a hard time anyway.
I may have crossed a threshold.
I crossed the threshold long ago. I've given away most of my knives to family and kept some pocket knives and a few mora's and my 2 Ontario 12 inch machetes.
I deceided to concentrate on survival technques instead of gear hording. Fire building, debri huts with available materials, use of sharp stone flakes if need be. Like one poster said, you can't loose knowledge in you head.
Any gear more than you can carry at one time is just overkill.
