Beautiful Tony Bose Stag! I've been admiring the mini Wharncliffe trapper patterns lately, and yours looks close to perfection if not perfect. Thanks for sharing :thumbup:
Thanks Jason! It's a great size, it's 3-5/8 closed. It carries like a bigger knife and will do anything a man needs in a days work! It's my favorite pattern to EDC! Thanks
again for the nice comments! Hope you get yourself one soon, You'll be glad you did!
Jason
Details needed!
Nothing too fancy. I noticed that, unlike most of my slipjoints, the cam on my 31048 stuck out a bit past the spring, and I thought to myself that I could file a flat spot and give my knife a half-stop (and that if I screwed it up, it's not exactly an expensive knife to replace). I used a SAK file, which worked well enough on the soft CV steel. Some patience and a steady hand, and now it has a half-stop. The end isn't completely square (still rounded on the edges), but it's flat and broad enough to give it a fairly positive stop, fairly crisp, and without much wobble to speak.
I tried to take a picture of it, but I can't get it to show up with my cell phone and low light.
Sounds great, that is what I figured you would do. I am going to try the same thing on mine, probably with a Leatherman as I don't have any SAKs with a file. This remedies one of the only shortcomings I could find in the otherwise excellent slimline trapper. Thanks for the info!
If you try it yourself, and you want a 90° angle in the half-open position, don't file perpendicular to the handle. Put a slight angle on your filing, just a few degrees, at the angle that would make you think that would make the half-open position slightly obtuse. Thankfully, since you'll be filing beyond your initial cuts, there's some trial-and-error on the angle that can be corrected without ruining it, as long as you make the full "grind" at the correct angle.
A buddy at work who knows im into old timey pocketknives gifted me a Case XX Trapper one dot today! It was badly rusted and dull as butter but I gave it a little bath and a sharpening and believe I will be carrying it tomorrow. I believe its a 89' model by the tang stamp but he swears its from the 70's. Ha!
Still hauling around this Le Compact by Chambriard...
very sleek folder and still one of the keenest edges I've put on a knife...
G2
I'm feeling tribal.... The chestnut bone Case puts out is soooo nice. It reminds me of freshly melted sugar sitting on top of creme brulee.....
