What did you cut and what did you do wrong to happen this ?In fact just last week I survived my first cutting wheel explosion, after years of using an angle grinder:
I have been using angle grinder since I was ten. Thousands of discs have been used. Pipes, solid iron, aluminum, bronze, wood, plastic .. I cut everything . I never broke the disc or exploded ...There are some rule about using it ....follow that and you will have no problem .Perhaps concentrating on what you are doing is the most important rule .It sucks when that happens. It feels like shards of glass hitting you as it’s flaking apart.
thin piece of sheet metal
I think it slightly is too. I still have to sharpen it but being aeb-l and it trying to warp on me already I was worried about going much thinner. Also I had made the handle already and didn’t want to thin it too much and it have a gap in the handle. But next one will be thinner for sure. I have never actually held a Japanese style knife so it was all based on pictures and videos. But it’s already thinner than the chef (8.5”) and 2 Santoku’s I have (8” and 6”) I have of my henkels so I feel it’ll still work great even though I may have left some performance on the table.Looks great I'm sure they'll love it.
I can't tell for sure from the photos, but it might be a little thick behind the edge. I've been steadily grinding mine thinner and thinner and they perform better and better (as long as you don't push it too far).
That is not hard spot in Aluminium , there is no such thing in that material .Al wants to stick on drill bits ..........Drill little , clean tip of drill bits ...drill-clean ....Obviously that is some soft aluminium you drill in ..In some Al alloys drilling hole is pleasure ........It's been a long time coming. My homebrew surface grinding attachment is nearly complete, and for a fraction of the cost of a bought SGA (~$360 vs $1000-1500). I had a lot of fun building this one, but I don't know if I'd ever want to drill so many holes in aluminum again. I found it to be an odd material, machining-wise. The drill bits have to be brand new or they will only melt the aluminum. Drills like butter with a sharp bit until you run into a hard spot that squeals and you gotta add some more oil to keep going.
It's 6061. Hard spot probably isn't the right wording, it's just what I was feeling.That is not hard spot in Aluminium , there is no such thing in that material .Al wants to stick on drill bits ..........Drill little , clean tip of drill bits ...drill-clean ....Obviously that is some soft aluminium you drill in ..In some Al alloys drilling hole is pleasure ........
