Richard338
- May 3, 2005
Magnacut at 62 HRC. 10" hollow.
Will soon have carbon fiber scales.
Outstanding! Don't you usually win a plaque when you make one that nice?One I finished for a lady client
3-5/8 lockback Cpm154 blade and spring, 416 integral liners and bolsters.
Alice Carter engraving.
Beautiful knife!One I finished for a lady client
Oh man, that's lovely!Been working on some forged wrought iron and hamons recently
Why just for thin steel ? This two pieces are 4.5mm thick CPM S30V hardened on 62 Hrc .Straight as it can be straight . Now I need to decide which design the knives should be and continue with the work. There are even advantages to this method. There is no fear of cracking, warping of steel , hardness after HT protocol ......All I need to know is there before I start to work on steel . It's not very pleasant when after so much effort to finish the knife, something happens during hardening and the knife ends up in the trash...............I am right ?
mknife , all that is valid for soft steel in HT process ? Holes are potential stress point , shape of knife , grinded bevels can be reason for wrap .......etc .Almost every hidden tang shape knife I quenched get less or more bend in ricasso/tang area. Then I start to leave tang unshaped and bending no more in that place ...........I understand your point of view, but I don't see why not to do a whole series of operations before tempering, for example: profiling the knife, and drilling. You could also make a coarse grind of the blade. These are steps that take you little time and that avoid stress on the already hardened steel.
I often send blank rectangles of steel off for heat treating (usually with at least one handle hole) and do the profile after they are hard. Belts eat hardened steel and if I need to remove a lot, I use a angle grinder with a diamond cutting blade to rough it out more. I cut farther away and then grind to shape. It's not too bad and that way, I can send a large batch out for HT and have options in terms of what I make with the blanks. I can go from a hardened blank to a finished knife in a day or two as well, so when I have them on hand, I can get orders done pretty quickly! If I send a blade out to HT fully profiled, I am locked into that shape, where if I leave it very oversized or rectangle, I can do what I want with it.
