America has reached 250 years, and I am grateful to be here, in the best country in the world. Thank every one of you who helps make this country a better place, those who have gone before and risked it all, and those who've paid the ultimate price to make the United States what we are today.
I have a love/hate relationship with Suretouch. Very nice.
Now grind full flat or hollow bevels and all that work for what ?I am all new to surface grinding. Just recently got an SGA and now it's up and running after a couple of fixes.
What is your grit progression when doing this??
I found it neccessary to start with 120 ceramic to remove peening marks and decarb. Then 220 ceramic and finally A45 Trizact (appr P400). I will finish with a little hand sanding with P400.
The blade is an updated hunter profile Magnacut that should be at 62 hrc if I've done things right.
Your local weld shop should carry a product to find weld leaks. I don't remember what it's called but they will know. I believe it requires a UV light, but then again maybe not.Getting pretty close to being done with this quench tank I made. I just welded some steel I had laying around together, and bought a hinge for 2 dollars for the lid I made. Then put some self etching primer, and painted to hopefully keep the outside from rusting. I'm assuming the oil will protect the inside.
I typed that first part before I tried filling it up. Afterwards I've been having a heck of a time trying to get it leak free. The main problem is I just can't completely tell where the leaks are, because the holes must be tiny. Because I cant see them with the naked eye. So now it's a mess of welds on welds trying to fix it. Super frustrating.
It was flux core. So basically mig welding. I mean it's fine for structural stuff but, its definitely been a problem with this. The mai. Reason I havent done anything like jbweld, was because I wasn't sure how effective it would be on something containing oil.How was it welded? A friend said he always had leaks with Mig welding, but Tig welding disnt have the leaks. I used the gorilla spray leak stopper stuff on my tanks after slathering the weld joints with a thick layer of JB weld.
One thing I'm concerned about is putting something inside that could contaminate the parks 50 if I don't clean it all out.Your local weld shop should carry a product to find weld leaks. I don't remember what it's called but they will know. I believe it requires a UV light, but then again maybe not.
Ok I'll go ahead and try that now. The storm knocked out the power here so nothing better to do.Once JB Weld cures, I don't think oil affects it at all? I used both tanks a few times (Parks 50 in a 4x4 tube and AAA in a 6" diam cylinder, both 24" tall) and it seems to be fine!
I'm not sure, but I believe it's put on the outside of the weld. I'll see what I can find outOne thing I'm concerned about is putting something inside that could contaminate the parks 50 if I don't clean it all out.
One product I found is calledI'm not sure, but I believe it's put on the outside of the weld. I'll see what I can find out
