What's going on in your shop? Show us whats going on, and talk a bit about your work!
Just to clarify about a glass platen:
A "glass" platen for a grinder is pyroceramic glass. It can withstand around 1500°F without breaking. It is very hard (Rockwell 60) and strong when glued to a solid backing plate. It is designed for high heat situations like fireplace doors. The main reason for using it on a grinder is it is very flat, cheap, and readily available. I hear people say they wear it down fast. I have only ever replaced a pyroceramic platen when I broke it by setting the arm down on the floor too hard. I never saw any wear on the surface otherwise.
Tempered glass is designed for windows and entry doors to resist impact. When the impact is greater than its yield strength (about 3 times the IMPACT resistance over pyroceramic) it is designed to shatter into thousands of 1/4"/6mm pieces with no sharp points. It isn't harder, just tougher than pyroceramic glass.
Since a glass lined platen should not be receiving impact, that is a moot point. What a platen does receive is considerable heat. Tempered glass would be very inadequate for many of us who do hogging of blades.
Tempered glass is harder then ceramic glass . Tempered glass can withstand more temperature then you will ever create while you *hogging* steel .
Well , I make phone call today . Friend have glass factory so they will deliver it to me tomorrow. 26 x 5 x 0.8 centimeters so I can make some test and compare them
I'll just let it go .. but checked again with the manufacturers and the info I gave was from their site. I agree that tempered glass is harder, but it is not 4 times harder. The temperature tolerance is much greater for pyroceramic glass. I hope your experiment works well.
Have these eight on the bench post heat treat and temper - walking them through all the different grits today, 120, 240, 320, 400, and a 500 Rouge Impregnated Scotch-Brite and cutting some guards for them - Boat Load of Knives ~ Big Bertha looks sort a like a Sled ~ I like it ~ Stout Bowie and Cleaver in one ~
Got them all done on the different sanding belts and 500 rouge + scotch brite, think I'm going to get to the guards another day, possibly tomorrow ~
View attachment 2109118View attachment 2109119
View attachment 2109120View attachment 2109121View attachment 2109122View attachment 2109123View attachment 2109124
That big Bertha is super cool.
On impact . Come on Stacy , we don't use ceramic glass for quenching AEB-L so higher temperature tolerance is not important here . Why not to try when I can ? Thickness matter also , I can order inch thick tempered glass , that is not case with ceramic glass .
Well I ordered one but I get four :) That MF for sure would ask something from me ..............🤣 It seems to me that I will overpay for these glasses , it would be better if I paid right away . I'm kidding. What a fool I am !!! The measurements I took for the glasses for this plate are for grinder which still does not exist , it is not finished , so I can not test this glass right now !
Got home from work and a nice bar of S90V was waiting for me from NJ Steel Baron. Decided to work on a few more of these EDC designs. This one was profiled, drilled and the tang is tapered to .040 at the butt.
I have a question for everyone. When I grind a pattern for the first time (or even second) am I the only one that brings that blade/blank in and fiddle with it to get a feel and decide if certain aspects should be changed, like removing a fraction of an inch from the butt, or drop the point a tad.
Now mind you, I'm not talking about feeling the blade in my hand in the shop for a few minutes, I'm talking sitting on the couch, watching Archer or whatever for days.
Am I the only one?
Am I the only one?
All my blades have a "fiddle time". Sometimes the changes come to me in my sleep.
DangerZone!! Love Archer!
I tweak the design and play with almost all of my blades. I don't have any set patterns yet.
I got ceramic Norax and Trizacts in finer grits and they actually work on hardened S90v!!
Am I the only one?
I do that and I enjoy it
Am I the only one?
The new ones for are get played with a bit trying to figure out the best handle shape or size and materials. Even the old patterns get some attention when trying different handle options.
Am I the only one?
The fondling time is my favorite time. Like figuring out the “buttons” on a new girlfriend.
I think anyone who looks for 'what's normal' in Bladeforums isn't going to find much
Am I the only one?
you're not the only one
this one will definitely be getting a lot of fondle time
