I'm right handed, but for some reason when pulling my blades, I do a better job with my left hand. I shoot pistols better left handed too (slower, but more accurate)Today was also a bit of an "ah-ha" moment. I was grinding one of the new batch of drop points and two things happened.
1. I am right hand dominant, which means I sometimes have difficulty grinding with my left hand. Despite years of practice, I sometimes still get a bit of a wiggle in my grind towards the tip that I have to correct later with files and sandpaper. Today I learned to flip the knife over (edge down) and use my strong hand to correct the grind. Worked VERY well.
2. I have a J-Flex belt in my shop that I just never used, relying on sand paper and my surface plate to correct the plunges, which works well, but is time consuming. Now I see what the use of a J-flex is!, I will still need to finish the plunges on the granite plate, but it took way less time!
Oh, and here is what I love about tapered tangs...can you tell which side is the blade and which side is the tang?
I would not call this * simple knife pattern * . It is * most useful pattern * . No need to * invent hot water * again . Useful / working knife are made thousands of years before us.Testing out this simple knife pattern in hopes of making a simple/easy template for gift knives. (8670 and Bocote / 4" blade and 4" broomstick shaped handle)
Finished this one today, Takefu vg10 sanmai 1.5mm / 1/16" steel thickness, 120mm/4.75" edge, japanese theme laser engraved. Redwood burl, with some burl spikes untouched at the end. Laser cut textured vegtan sheath.
Pablo
Ah yes. "Simple" in terms of simpler to make for me. lol. Since there are no odd lines/curves to work around I can make this pattern with less effort compared to others. I also largely prefer simple patters and broomstick handles. I was trying to make something that could serve in many roles and be useful to the broadest range or people for gifts and "thank you' s". I also hope this pattern will let me take advantage of a lot of handle materials like bone, horn and antler.I would not call this * simple knife pattern * . It is * most useful pattern * . No need to * invent hot water * again . Useful / working knife are made thousands of years before us.
Like it !
It's done! Next up for this hand engraved and anodized G&G Hawk Knives Deadlock is a date with Sharp By Coop Photography for a glamor shot!
Nice job! My question about tapered tangs is that they only really work with full flat grinds correct?Today was also a bit of an "ah-ha" moment. I was grinding one of the new batch of drop points and two things happened.
I was thinking you are going to come to the same conclusionQuick update, removed the spikes, usability trumps nice looking.
Used the knife this weekend at a BBQ and it wasn't comfortable at the end. Left some of the irregularities there, but no more spikes.
Pablo
Why is that? Bob Loveless did them on his hunters and they are hollow ground.Nice job! My question about tapered tangs is that they only really work with full flat grinds correct?
