SwissHeritageCo
- Jan 8, 2021
Then I see movement at my feet outta the blue. So I gloved up, opened the door and served an eviction.
This frog was trying to deliver a very important message to you... He was a bro and you didn't listen.
Pretty stoked about this project!
These are some custom fabricated bench dogs with a collar that is 3/16” tall. I’ll be installing them into a 1.5” thick piece of Richlite.
I use a combination of a 12” disc grinder and a 4” x 36” belt sander to clean up knife blocks for scales.
The 4” x 36” sander moves too fast to safely finish thin scales without the piece going flying, or losing some fingerprints. Because of that, I typically use a random orbit sander after the drum sander on scales that are under 3/8” thick (the drum sander doesn’t like the finer grits). It can be very hard to secure a piece that small, so I often hold the piece in my hand…. And I’m not trying to come down with vibration white finger.
I’m hoping this setup will allow me to secure scales as thin as a 1/4” to the piece of Richlite to make finish sanding scales for sale easier. It should be super quick and easy to swap out scales in the system too. We’ll see how it goes.
If it doesn’t work…. I’ll be spring for a custom made, variable speed 4x36” belt sander. Strangely there are zero true variable speed 4” belt sanders on the market. The closest I’ve found is a Jet for around a $1000 that only goes down to ~900sfm.
I need some of your focus and energy, it's impressive.
