- Jun 6, 2005
I had a completely different experience the first time I held one. I noticed a handful of details immediately that set it apart, and even more as I got to know and use it more.
The knife is very soft in the hand. All the edges are rounded to perfection, evenly and attractively, including the spine of the blade and the inside of the lock bar. I have never had a knife finished this well on ever single inch of the handle and blade.
Everything was lined up and fit together perfectly. I have never, ever had a perfect knife until I got a Sebenza. Not a single rough spot, nothing not lined up exactly to the fraction of a millimeter. You would have to be extremely lucky to get a knife like this from a regular factory.
The lock up is the most perfect, solid lock up I have ever seen. You can fully remove the male side of the pivot pin and still have rock solid action with zero play in the blade. Try that with another folder.
The pivot bushing allows for perfect action and lock up every time with no pivot adjustment or Loctite, ever.
The simplicity and ease of disassembly is a marvel as well. The knife only has sixteen pieces, total, and can be easily disassembled and reassembled perfectly in minutes due to the absolute perfect tolerances the pieces are brought to. Every piece fits like a well make jigsaw puzzle, sliding in with ease and authority, with no room for movement.
The design itself is quite remarkable. It is slim and elegant, with fantastic blade to handle ratio and balance. These are just opinions, however.
The Sebenza is the closest thing to perfect I've ever held in a folder, period. I've had many, many Spydercos, Benchmade, Kershaws, Striders, Bucks etc. etc. I noticed the differences immediately. The quality difference is real, the knife community isn't pulling anybodies leg on this one. Don't listen to haters and their sour grapes. If you know quality folders and have an eye for quality, you will see the differences.
