Not sure I understand the line of thinking in the first part. Are you only speaking of vertical play? Or does a frame lock somehow help mitigate side to side play that other locks don't?None. That’s why I like my framelocks… Hinderer and ZT especially
This exactly. Seki lockbacks and other "older" style lockbacks a small amount of lock rock is ok. Anything else no thanks.Depends. Some traditional lockback knives have a bit of blade play (means if I grab the blade with my fingers I can force it up and down a tiny bit), and I'm OK with that. For a truly traditional design, it's difficult to eliminate vertical blade play. The tolerances required to eliminate blade play on such a knife are incredibly tight.
On many modern lockbacks, the designers have diddled with the geometry of the lock interface, and I seldom find blade play on those.
I don't accept vertical blade play on other types of locks. If there is any the knife goes into the "for reference only, do not carry" box.
I'm not OK with side-to side blade play in the open position on any knife.
Ditto, I only really tolerate the minimal vertical play that appears in some of my FRN Spydercos from Seki.Normally I would say zero. But I just picked up a Delica 4 with slight vertical play, very slight. My understanding is that sypdercos opinion is that is normal. So in this case I am accepting it.
I was talking about both. In my experience if a frame lock has a small amount of side to side it can usually be tuned out by tightening the pivot just a hair. And still have good action of course.Not sure I understand the line of thinking in the first part. Are you only speaking of vertical play? Or does a frame lock somehow help mitigate side to side play that other locks don't?
Either way, I'm not sure a frame lock has anything to do with blade play more than any other lock.
