- Jan 22, 2011
I want a specific blade length and I want it attached to a big enough handle. Beyond that, the relationship between the two just isn't important to me.
Yesh.
Lol...
What matters most is the distance from the start of the edge to the end at the tip as the crow flies, which is the cross sectional cutting area. A serrated or kris style blade technically has "more" cutting edge, but that's typically not what matters. Somewhat related, read up on the Coastline Paradox
I think you are right. But I think it's a shame that things like Edge/OAL and Edge/mass are unimportant to most users. Of course that's not all people should consider, but I think it would be good if they did pay some attention to things like that. It may lead to better and more elegant designs
I apologise if I'm using terminology wrong. I just used the term "cross sectional cutting area" because that's what makes sense to me. What would you call it?First, that is not the "cross sectional cutting area."
Second, that is not what matters...what matters is the length of the edge.
Third, the "Coastline Paradox" would apply to ALL blades, not just serrated or kris blades, and if you are going to invoke it, then your "edge length" numbers from above go out the window also. Read up on it.
I'm aware of the Coastline Paradox and I know you could apply it to all blades, the extreme case of going down to the molecular level and measuring all the ridges and microserrations formed by the carbides and whatnot... hence why I was cautioning against invoking the coastline paradox, claiming that what matters is the distance from the beginning of the edge to the end as the crow flies. Just so I can understand what you're saying, here's an example of a kris. Are you saying that the length of the blue line matters more? Because it seems to me that the length of the green line (delta) is what matters in most cases. Once you straighten out the blue measurement it might be 3.5 inches vs 3 inches for the green, but it doesn't mean you'll be able to slice through 3.5 inches of cake. I guess another way of saying it is that the blue line ("real" edge length?) doesn't reflect the actual reach of the edge. Am I understanding you right?
I agree with you in that what makes a good knife is much more subjective art than science, but I argue that there are some objective metrics that do matter, and they shouldn't be totally disregarded. I guess how much they matter is the debate here... they seem to matter very little to most folks which puts me in the minorityWe shouldn't laugh at subjective science!
Well put! I'm going to remember that peanut butter scenarioYes, that blue line is not going to get you any closer to the bottom of the peanut butter jar.
And if I'm heading for the bottom of the peanut butter jar, I want peanut butter on more of the blade than the handle.
Hence, Blade to Handle ratio is very important to me. In the PBJ sense.
On a Kind Of/Not Really related note, I like a certain amount of cutting edge... 3-ish inches. Also, I like my folders to take up as little room in my pocket as they can. So I suppose, indirectly, that my criteria favors a better handle to cutting edge ratio.
But I still want the peanut butter on the blade, and not the handle or my knuckles thank you.
Well, no. In the peanut butter scenario blade length is all that matters, not ratio. My Military will get more peanut butter than my Liong Mah GSD, regardless of ratio.
