- May 5, 2013
I made the mistake of letting my Gayle Bradley (CPM-M4) get too dull. It was a bear to get back to a "razor" edge or whatever, but with stropping and touching up on ultrafine sharpmaker stones, it has been fine. Its all a learning process. To me, you can't just start with a "super" steel. You need to learn to work with and maintain a medium grade steel, like 154cm or D2.
Currently, now that I have some decent sharpening skill, I find S35VN and CTS-XHP my favorites.
In both my opinion and experience, it is better to start with a lower tier steel and learn to care for it than to jump in to the high end steel market right away. With softer, less wear resistant steels, it no only is easier to sharpen them but it is easier to correct a mistake. If you find you have a natural talent with sharpening, working with super steels will be easier.
For the first time ever, I have to gracefully disagree with you, K.O.D....I hope you don't hate me!!
A steel that is "softer" doesn't make sense to me?!
Do you mean like, has a higher Carbon content and less Chromium and Vanadium?
I don't think the steel matters all that much when it comes to ease of sharpening....once you know what you're doing, it's just a matter of doing it.
I find no difference in sharpening D2 vs 154 vs M390....re profiling, that's where it gets a little more tricky....
I think it's obvious what happens when you run a steel too soft (if that's what you mean) for the sake of saying "it will be easier to sharpen" there is a maker/company we all know that runs this theory, and the edge retention on their knives is well below that steels capability.
So what happens? You need to sharpen more....
The OP want's to sharpen less, and that is why I recommended the steels I did.
I went almost 2 months with CPM20CV (lots of hard use, and miles of cardboard) and stropped it two times. It's ability to hold it's fine edge was so good that I sold the knife because I like to sharpen.....
If I compare that to CPM-154/M4/3V/S30V (which I have used a TON) .... Example, not scientific ....
Take 10 large double ply cardboard boxes and cut 5 up into small pieces with 154/M4/3V/S30V and 5 with 20CV (or the family)
The 154/M4/3V/S30V will be at a solid working edge somewhere before you're done.
20CV (and family) will retain the fine edge you started with.
