Things I have learned from this thread:
1) as long as the geometry is good, you can make a knife out of a Coke's Can and it will cut as well as any other Supersteel. It will eventually hold its edge a little less long, but it will be easy to touch up. Just a couple or three strops between each cut.
2) it is incredible the amount of Choco Pudding which I can eat while choosing knives. I will probably end up posting a sidekick thread of Ankerson's Edge Retention, with the number of spoons of Choco Pudding which I can eat while reading about each of those steels. For fairness of comparison I will consider the hardness of each pudding.
3) heat treatments can make even the air of a thread hot, specially if it's BOS' one.
4) chances are good that no matter which Steel I will choose I will be satisfied. Or unsatisfied.
In any case I will spend the rest of my days sharpening.
5) I will sleep more than 4 hours a night only when I will get my damn knife.
So, I was thinking that I was ready to chose a knife, or at least to propose you for examination and suggestions a list of possibilities, when I have re-read some comments and decided that I still needed to investigate on a few subjects.
Please be so kind to give me assistance a bit more
But since you mentioned keeping a fine edge versus a coarser edge then I'd probably look for cruwear from spyderco considering the totality of the circumstances: availability/relative ease of sharpening/toughness/fine edge retention/hard carbide content.
Could you (or anybody else) explain more this of coarse/fine?
Does "coarse" mean teethed, and fine = polished?
Is that strictly related to the sharpening, with coarse being caused by a lower grit and fine by a higher grit?
What is the relation between the coarse/fine thing, and the "holds the razor edge longer" vs "holds the working edge longer"?
Do all steels mentioned in this thread support well both fine and coarse edges?
I read that teethed edges seem sharper but then the teeth tend to break, and that's why a fine edge should be better. So, when should one prefer coarse or fine?
We talk about other things like "edge stability"
Which of the steels mentioned in this thread offer better edge stability?
I do work very similar to yours. Because corrosion resistance is so important, I limit my bladesto stainless steels. For one of my current work knIves, I m using the griptilian in m390 steel. Exclusive from one of our dealers, and a very tough work knife. In your price range.
Also agree with surfing gringo, except I would consider s35v for better toughness than s30v.
How would you compare, given our job, the M390 and the S35VN?
And, did you try a M4 or 10V and could notice any rust problem?
Did you ever have problems of locking mechanism not locking, due to dirt or even rust (caused by old wet dirt not properly/timely cleaned)?
All steels are easy to sharpen when you use diamonds! I'm serious.
Diamonds are forever.
(just wanted to say that)
I agree with you except for M4. I use two M4 knives to slice up boxes from all of our Amazon shipments.
One day I got bored and used my 562CF
These are 2 of the knives I am considering, Benchmade Contego, and ZT 0562CF. Could you compare them?
To sum that entire part up, blade geometry > blade steel (assuming both steels will get the job done for the task at hand). So try to pick your blade based on that than decide what steel you need out of your options if what you want is performance. It's a lot easier to cut with a scalpel than an axe after all.
...take a look at the Manix 2 in S110v in before and after the regrind in performance. That's a pretty large jump in just changing the blade geometry in regrinding it. So keep that in mind, blade steel is only one part of the equation for performance.
To you and to everybody else: considering only the Geometry, in which order of preference would these 4 knives be placed, for what I am looking for?
Benchmade Nakamura
Benchmade Contego (so, how much in danger of rust would the M4 be?)
Spyderco Para 2
Spyderco Manix 2
ZT 0620CF
ZT 0562CF
And, how to I reprofile / regrind a knife? Would a Sharpmaker with Diamond Rods be ok?
And which of the steels mentioned in this thread allow a thinner edge? (thinner, not fine)?
It will depend a lot of the actual knives really, in Customs with a good HT M4 is very nice indeed and does hold an edge for a very long time.
Calc wrote that M4 holds a razor edge longer, while M390 holds the working edge longer (which remembers me of the 154cm vs s30v debate).
Did you also notice that, and if yes could you say why?
I look for the steels which hold the razor edge (much) longer. The utility edge is not of my interest. I will keep my knife at Razor Edge level.
I have also noticed that in your Review of Edge Retention you did not put the S110V in the first list. Where would you place it, in which category?
And one last question for everybody: which locking mechanism should I prefer given my situation?
I have been looking at videos.
The Manix does not seem very strong. A guy was able to unlock it by beating the ground with the back of the spine. Besides, I wonder if the dirt (soil/mud) would not block the spring..., and eventually rust it.
Same story with the Axis...
The frame lock of the ZT should be fine, and the Compression of the Para 2 even better.
Thoughts?
Thanks!
