Awesome I'll pick one up in short order, also, I'm looking for the vid 'sharpening with scythe stone- scythe.'
Did you make that one? I'm not seeing it. Subcribed btw![]()
So...I inquired with my sharpening stone manufacturer about mounted grinding points and if there was a grade they would consider appropriate for grinding the thin, hardened steel edges of scythe blades without burning them, and my guy sent me a couple of sample A3 points in a suggested resin bonded blend. I did some experiments with it chucked up in a common hand drill and it produced excellent results. I was able to grind at a suitably low angle, at a skew to the edge to set the direction of scratch, and it removed steel at a very controllable rate with absolutely zero perceptible heat buildup even when I deliberately worked one narrow region continuously at max rpm. I think the cheapo solution for grinding American blades has been found! They're more expensive than some other mounted points, but at $12 retail, they're still extremely economical.
Just had this little beauty land. I already have a couple, but this one is absolutely mint, complete with (battered) box.
