- Jul 22, 2009
Here's the thing you're not getting. Nobody is required to eliminate all variables in their own personal use. If I find S90V to last longer than D2 in cutting corn, then that's good enough for me, because I'm cutting corn and not 1/2" rope. If other people reach the same conclusion in cutting drywall, then it's also good because they are cutting drywall and not 1/2" rope. If other people reach the same conclusion cutting cardboard, then that is also good because they are cutting cardboard and not 1/2" rope.Yes my little World of 1/2" Manila rope cut 200 times isolated from hitting base, measuring sharpness in a process. It may be little, but it least it is real.
You created some mythical World of chatting to each other, and more you chat - more real it appear to you. You support each other and attack anyone who sceptical about your believes. Most interesting is that "testing show" which meant to prove this mythology. With "flexible" procedure and undisclosed raw data it is perfect to "prove" what you already believed.
Fortunately there was a class in University - "Scientific methodology". One of the proves of right testing is unexpected or unknown before results which then proven by independent testing.
In case of my testing - I found poor quality of SGPS, then it was also demonstrated independently by BLUNTRUTH4U. I found average performance on CPM S30V - also later CATRA tests where published with same data.
Now I rather believe in my test results then to chorus of voices here saying that CPM D2 should not be better then CPM S90V. Why should I? Show me test results (I mean real test not test show) then I may have a look. The fact that so many people here talk about that a lot - does not impressed me at all, after being on this forum for over eight years and thousands spend on super steels with average or poor performance, I learn that I should test blade performance myself and do not trust to commonly accepted opinions.
Thanks, Vassili.
I'm not sure how to explain this to you, but if I find that S90V does better on cardboard, drywall, fiberglass, corn, and wood, but only does bad on 1/2" rope, whereas D2 does excellent on 1/2" rope but fails at cutting drywall, wood, corn, fiberglass, and cardboard, then I'm going to go with S90V see? These are things you need to take into consideration in real world use.
And as much as I praise S90V for being an all-rounder, I think I'm still going to stick with ZDP-189 in the kitchen. So I tell you what, if I'm ever faced with a pile of 1/2" rope that needs to be cut, I promise I'll break out my Dozier Buffalo River Hunter, just for you. Okie dokie
As cute as your supposed scientific methodology is, it doesn't seem like the real world ever factors into your equations. I say this because you yourself admitted that in your testing methods, you would continue to make the same amount of cuts with both knives even if you have to muscle down 100lbs of force on the 200th cut when most of us would have stopped at that point and called it dull. This is the crucial difference between you and Ankerson, because he acknowledges that an edge that requires more than 20 lbs of down force in a cut would no longer hold any practical use for any of us. Because I am not going to put the corn on the floor and step on the spine of the blade to force that cut see?
