- Apr 21, 2006
As I struggle to understand this, I think Vassili has a point. Wear resistance and edge retention are often used as synonyms, but reality is more complicated.
Wear resistance is what it is, and it will typically correlate to edge retention, but not always. Hardness and blade geometry and the size of carbides, etc., will affect edge retention.
For example, a steel at a specific wear resistance and hardness may have excellent edge retention on a knife with a 40-degree inclusive edge angle. But if the angle of the edge is made much more acute, the edge will roll or bend or chip, reducing edge retention to average or poor.
Edge retention is affected by more factors than wear resistance.
Twin dog, what you are referring to is actually edge stability. Edges rolling have nothing to do with wear resistance. It means the steel didn't have enough stability to do that edge on that particular job and rolled. Chipping away could be another result. Micro chipping, not obviously a large chip from an impact on something hard like a nail in a log being batoned, for instance.
Wear resistance is either abrasive or adhesive wear resistance. These two types of wear resistance are measured and are what the steel companies list in the specs on a steel.
As I stated in an earlier post edge stability can have an effect on wear resistance but by and large wear resistance comes from the carbides and steel matrix structure. With some steels acidity can even lower wear resistance. Typically, the higher the carbide fraction of a steel, the lower the edge stability. PM technology has helped in this greatly allowing the steels to , as Crucible states" The CPM process results in a finer, more uniform carbide distribution imparting improved toughness and grindability to high alloy steels".
Like recently one "steel guru" revealed what was his theory on PM steel were based - once he change old carpet in his room and use three knives,
CPM S30V one outperforms BM D2 (on my tests BM D2 show worse results) based on this comparison - average CPM S30V vs worse D2 he made big
theory that PM steel with higher carbide volume better. Very interesting reading he came up, which show true power of imagination, but this has
nothing to do with little World of reality..
I suppose you are referring to me as I was the one who was talking about my experiences cutting carpet, and what I learned. I'll say the same thing that I said last time you said this though I have no reason to think it will sink in, or you will understand it. I only stated that I had found that for that particular job, my results were... You couldn't accept that and stated your testing was better and more accurate than my real cutting experience. It was kind of puzzling how you came to that conclusion that your testing was better than real world experience. In fact, I still don't get it.
I've collected, used, bought, sold ( retail on the gun show circut), and even made a few knives up until I lost the space for a shop, and had to have both shoulders srurgically rebuilt.
In that time do you suppose all I ever did was cut an old carpet once and that sums up my experience with knives?
Saying the same things over and over to you really gets old. My mastiff is smarter and learns quicker than you. You should stay in your world of computer programming. You obviously don't understand or get along with real people as you eventually make yourself unwelcome and get ridiculed for your attitude and behavior in every knife forum you participate in. You have terrible coping abilities with and around people and you are the cause of your own problems. We all gave you the benefit of the doubt , and even supported you and your work for a very long time. Some of us more than others. It would be easy to point out what you are doing wrong here but that's been done enough times. You choose to not get along with people for whatever reason.
The difference between you and me is I recognize I have a huge amount to learn about this subject. I admit to being wrong, and not knowing what I don't know. A "Guru" I'm for sure not. I lurk far more than I post here because I'm always looking to learn stuff. I'll take whatever knowledge someone is willing to share with me and try to learn from it. When I make mistakes I try to learn from them and not repeat them over and over. That's another way we differ.
Joe
