again I'm with Bruce but I will kneel to the majority
here-s run down as I see it so far.
yes I will need the blade here before the heat treat and the
tapering of the tang I e-mailed Bruce about this and he
agrees with me,
it will be much easier for me to do what I have to do,
Bruce and I think we should be careful how thin the tang gets
ground also...
and an after thought? we should (not) hollow the tang
like we/some do for epoxies to fill this void...
will this be the sequence of work?
Damascus made ( Nick )
Mokume made ( Sean )
both cleaned up ( ??? )
the design and blank profiling (Michael)
pre finish surface (??? )
Jade cutting work (John)
other jade work (Roger)
work on the handle holes, fit of the parts. (Dan G)
then blade grind (Dave)
then the tang tapering ( Dave )?
then to the heat treat (Roger)
back to regrind bevel and Tang (Dave)
blade finish prior to etching ( Steve)
profile the handle parts (Dan G or Roger?)
finish the handle parts (Dan G or Roger?)
then etch ( ?? )
then to the names etched in ( Bruce Bump )
then the sheath ( Jay )
then to dan K for Pictures and the certificate.(Dan K )
then pass around for signing
is this close to what's going to happen?
please edit it and add the names to each duty then I can post it on the site. it's going to be good
http://www.knivesby.com/collaboration.html
edited because I screwed Up names
