A good chopper has much superior control and speed over any hatchet, therefore it's easier to use, it requires less force while maintaining precision, so you are able to cut more stuff in less time. Only an dedicate axe outguns a chopper, but then again, you won't haul such behemoth on a hike...I used to prefer large choppers first too until I convexed and sharpened a cheap Canadian tire hatchet. I personally did a comparison between a chopper and a hatchet but that was before I became involved in BFC so I have no pics. It will perform better at everything a chopper does with the exeption of cutting down small standing saplings, but it does that great too. It can also be choked up on like an ulu for fine whittling or food prep. I like my fiskars hatchet so much that I'm gonna put micarta around the shaft for a better grip and also try and stuff a small psk in there. If it means anything to anyone, if I could only have one sharp object in the woods, it would be a hatchet.
Great "testing", and very informative.
However....
Here's something else to consider:
When one is under duress (cold, wet, fatigued) it is far easier to maim oneself with a large chopper than with a locking folder.
When I was in the Army I once saw a young soldier, who was tired and cold and using an ax, miss his target and chop in to his own leg.
He had to be flown out of the field and back to the base hospital.
Had he been alone in a survival situation he might not have survived.
Larger choppers can save time, but they are much less forgiving of mistakes and accidents.
OHT, and i was warm and dry. Took approximately 45 minutes to build a nice frame,most of the time was spent whittling the limbs to cut them down.
You know, I'm rather surprised you didn't get a heart attack if you went three days without drinking anything and then hiked with a load on a hot day.
Anyways, I certainly agree that it's good to "field test" different scenarios, especially ones where your gear or yourself will be limited in ability. I've spent a lot of effort doing that - and it pays off to know what your limits are in different conditions.
I don't consider the SAK vs Kukri comparison to be a valid comparision of a small knife versus big knife, though. The SAK is a folder, and therefore a non-knife in the first place. That is, if you ask me. A small fixed blade is far more convenient for actual work, and not much harder to carry. Of course, it won't chop like a kukri, but then, I've never seen chopping as that all important.
I found it extremely interesting that you found the grip of the kukri comfortable to use in those conditions. Because, I find it absolutely awful in normal conditions. But then, tastes differ. That's why it's important to test these things for yourself, and not rely on what some Mors or Ray writes. :thumbup:
Sounds like you didn't use the saw? In my experience with up to about 2.5 inch diameter wood the SAK saw comes pretty close in speed to a medium sized chopper.
Nice test, which Khuk?
Ummm ok.nope, it was a blade test!![]()
my trusty Kabar Khukuri (stripped finish,and tarnished with mustard and hot sauce
i got apic of it somehwere, i'll dig it out!
You should have started this by saying that a large knife is better for you. Each will pick his own and why pick the SAK if you were not going to use the saw? The comparison would be much different IMO. If you compare just blades then compare a large fixed blade to a small fixed blade like the F-1.
