KingMC
The Pun-isher
- Jul 25, 2014
Again, 1095 is not know for its toughness.
You make me laugh
You make me laugh
Ontario 18" military machete.
Is that what whispered in your ear?
Or are you saying because they chose inexpensive 1095 for the machete, it must be the toughest carbon steel???
All carbon steels are "tough" compared to most stainless steels, but in the good, better, best categorization, 1095 is good. For a less expensive steel, 5160 is much, much tougher. 52100 is like 5160, but gets harder.
At high hardness he's right. 1095 is brittle compared to many other steels when run hard. There are lots of very tough 1095 blades out there, but they're all done at lower hardness to prevent them from being brittle. This is one of the reasons I often tell folks that even though Condor uses 1075 for their blades there won't be a significant perceptible difference between it and 1095 at its given hardness range. Although with careful testing you could, of course, measure some differences, it wouldn't be much.
Look, you haven't offered a single reason for your beliefs in this entire thread. The ability to sound imperious is not a replacement for being able to demonstrate knowledge or reason.
I owned an Ontario 18in machete for as long as I had the need, one one camping trip I batoned it through a 10" round, me holding 1 end and my brother using a 10lb log to bash on the other end. It bent at a 20° angle in the middle and twisted laterally as well as it made it's way through the round and around the knots, yet it survived without nary a scratch. We proceeded to do that 20 more times and yet it was still just as straight as before and still was sharp enough to make a feather stick.
We did this again on a different trip but in sub-freezing temperatures, it survived without a dent.
You want my beliefs? I believe you only care about numbers and don't actually have any real life experience dictating your thoughts, until you get some you're just some number-crunching know-it-all who only cares about being 'technically right' instead of actually knowing anything valuable.
You can't learn anything of value from one anecdotal experience. If your machete was made of 52100, it would have held up just as well at higher hardness. But you don't have a 52100 machete to compare it with, so you've decided you have the finest machete on earth from your sample size of one (1).
I don't understand why you fail to see the problem with that. Or why you think 42 and I are lying to you. Or any of the other reference materials you have chosen not to read.
Again, 1095 is not know for its toughness. Lower carbon steels are known for toughness and alloyed steels are known for toughness. At a given hardness, 1095 will be less tough than 1070, 52100, A2, S7 or 3V. At that hardness, 52100, A2 and 3V will hold an edge better.
I think you've heard something so often that you've believed it without any reason involved. Hypereutectoid steels sacrifice toughness for edge holding because the edge is full of carbide. 1095 makes a crude carbide. 52100 makes a finer carbide and finer resulting grain. Grain is where toughness comes from in the low alloy and basic steels. 1070 is tough because it doesn't have enough carbon to make any carbides. 1050 is even tougher because there is so little carbon that some spongy free iron is floating in the matrix.
Do you understand what carbides are?
Show me where you used 1095 and found it lacking.
Composition means nothing when heat treat can vastly change any steel's performance.
I didn't find it lacking. Like many people, I've used different knives outside and got excellent results with both basic and higher end steels. I just got better results when using the nicer steels, which isn't that surprising because that's why there ARE better steels in the first place.
I had thought dimensional stability during quenching was part of the appeal of medium quench steels like O1. If the steel is changing shape rapidly due to the thermal shock of brine or fast quench oil, does that not increase the likelihood of internal stresses?Lath martensite and grain size are 2 key variables behind toughness. Free iron is plain ductile (very narrow elastic zone => low yield point, so ain't tough) however if iron is well intersperse through out the matrix, which would help increase impact load.
Regardless of carbide type & size, it doesn't help with edge stability. Contiguous lath martensite lattice is much more stable than martensite with carbide inclusion because interface between martensite and carbide is weaker than pure lattice. Instability is proportional to carbide size.
With good ht, you can produce fine(sub 300nm dia) cementite/fe3c for 1095/52100/W2/so-on. 1095/52100/W2 (from Aldo) general produce around 3% carbide volume, so it's similar to 3V (2.7-3%cv), Aeb-L (2%-3%), except the latters have more alloying elements. 3V carbide size is actually quite large ~2-4um, so particle count is actually lower than finer carbide aebl/1095/52100/w2.
CrxCy / VC / WC / NbC / MoxCy have lower friability (i.e. stronger) than Fe3C (cementite), that's why other carbides are more wear resistant.
Quenching isn't a violent steel internal transformation, if you know why & how to produce orderly transformation. What you hear from quenching could be just steel thermal contraction (dimensional) from symphony of bazillion crystals. Otoh, if aust matrix is already in high dislocation/distressed - yeah quenching is probably will end up violent - crystals & grains crashing onto-each-other + probably crack interfaces between particles and matrix.
So what is the point of this thread, then? 1095 is good, other steels are worse or better respectively. Everybody knows this already. You only seem intent on proving everybody's opinions either false or irrelevant.
