- Apr 22, 2014
Entirely beside the point, the lock should function properly without assistance...and I can assure you it can happen in awkward cutting situations.How would a user ever accidentally spine whack with enough force WITHOUT having ANY force applied to the framelock to get it to disengage?
I agree that locks should function properly without assistance.Entirely beside the point, the lock should function properly without assistance...and I can assure you it can happen in awkward cutting situations.
What about linerlocks? Same lock interface with no chance of your hand backing it up...would you be ok with a liner lock slipping?
Sure, under normal cutting circumstances, but if you're pulling out of a stuck cut to reposition...force in the other direction. If the blade pops out of the cut and hits something because your in a tight area...spine tap.In all the years ive used folders,ive never seen a situation where the spine got hit in any way. the blade goes forward during cutting(duh) so does the spine.not sure how relevant this test is in the 1st place,as someone else pointed out...
Touche, but even in a case like that you'd need to be quite aggressive and careless.Sure, under normal cutting circumstances, but if you're pulling out of a stuck cut to reposition...force in the other direction. If the blade pops out of the cut and hits something because your in a tight area...spine tap.
Or in a less than ideal situation trying to get home...weird things happen and the last thing I need in a pinch is a bad cut on top of whatever problem I'm trying to fix.Touche, but even in a case like that you'd need to be quite aggressive and careless.
Yeah, I would agree that liner locks are less safe than frame locks if grip strength is included in the strength equations.Or in a less than ideal situation trying to get home...weird things happen and the last thing I need in a pinch is a bad cut on top of whatever problem I'm trying to fix.
Shirogorov lock geometry seems very straight and not radius or angled like some others.
I think certain geometry makes for a good slip point to dislodge the frame/liner lock if reverse shock is applied.
That could be what they have the travel stop to prevent the lock from going too deep with the shallow angles.
I finally got my first chris reeves knife it's a tanto inkosi and because I cant work I cant get any more other knive so I have to live threw other people with knives or a collection
