- Jan 28, 2006
Mongrel made a point that I want to elaborate on.
I read multiple times in this thread about how axes (I'm including hatchets in the "axe" description) are more dangerous because you have to hold the wood while swinging at it. Not to sound condescending, but if you are doing this, you don't know how to use an axe.
There's three ways to safely split with an axe.
1.) The one Mongrel described. Put the axe head against the top of the log, lift both and bring both down together to start the cut. Once the axe head is embedded, you can lift both together with just the pressure on the axe head and get a good, two-handed swing in.
2.) A variation on the above, where you hold the axe head on the side of the log, bring both down, ad give a little twist as the axe head embeds itself. Often with small branches you can split them with 2 or 3, sometimes as few as 1 swing -- much faster than batoning a knife.
3.) The third is to put the log on the ground, put the axe head on top of it, either starting it like in example 1, or resting it there, holding the log vertical with the pressure, and. . .here is come. . .da, da, da. . .BATON it. You baton it by striking the poll with a WOODEN baton (if an axe man sees you batoning the poll with another axe or hammer, he'll baton you). Once the head is embedded, finish the split as in example 1. Or, if using an all-steel axe like an Estwing or Craftsman, you could baton it all the way through striking the handle.
BTW, you can also baton an axe to make notches, or to make more precise splits to get the most planking from as log as possible.
