- Aug 28, 2009
I know. To this day, that 600 Lbs. is still amazing to me.
They did a whole lot more with the XL. To this day I still can't understand the mechanics of a larger knife with the same blade thickness holding that much more weight?
A bali is only as strong as the top handle pivot pin and blade stop pin. The latch does not matter. ( although my testing is limited). I am only referring to a blade in vise weight hang test. However, a Bali is equally as strong both directions. spine and edge pressure.
Only when the handles and blade butt are symmetrical. There are many handles that are not these days. Certainly they are very close in strength most cases.
I thought that with the handle locked up at the tail the lock might (and I am only testing this with my armchair) be greater for the same reason that the Tri ad gains strength with the negative pressure being transferred through the handle back to the top by way of the stop pin (it would need to be a close tolerance lock for sure). I feel the overall strengths of the ballisong could be greatly improved if the handles were interlocking when in the open position. Then the interlock would also take some of the stress both positive and negative.
