james terrio
Sharpest Knife in the Light Socket
- Apr 15, 2010
AEBL has only 0.66% carbon with 13% Cr so it would never be the same as hypereutectoid carbon steel like 52100(Bohler's R100) which has 1%C and 1.5Cr. The structure matrix of both would be totally difference.
Testing of, and micrographs of those steels at the same hardnesses bely your claims. They are NOT totally different at all, in practice at knife-size sections and hardnesses... the only demonstrable difference in actual knife blades is, AEB-L has a whole lot of free chrome that adds corrosion resistance, 52100 does not. That's exactly what it was designed for, nearly a century ago.
Of course AEB-L is not hypereutectoid, that's the whole point behind its chemistry. It has a little more carbon than is required to reach 62Rc in austenization, with almost no carbon left over to form carbides with the chrome. With deep cryo, it can reach somewhat higher hardnesses. Nearly all the chromium is free - hence, high corrosion resistance without sacrificing the toughness inherent in a "simple" euctectoid steel.
52100 has twice the carbon and a touch of chrome and a signifigant amount of manganese - not for carbide formation, but specifically for deep-hardening and hot-hardness; meaning it stays hard under pressure/heat/friction. Because it was designed for bearings, not fine-edged cutting implements.
Your understanding of how steels harden, and how carbides form, and why that would be good for one tool or another, seems to be deeply flawed. The notion that more carbon automatically makes a more resilient, tougher, or finer edge is simply not true. If that were true, highly-alloyed steels like CPM-154 and Elmax and XHP would be way, way better because they have even more carbon... and cast iron would be the best of all. But that's just not how it works.
Do yourself a favor and look up lathe vs. plate martensite, to start with.... before you even consider carbide formation and how alloying elements affect HT responses.
We're getting into the territory of side-stepping data and talking louder to obscure facts. I'm disappointed, but not particularly surprised.
