- Nov 9, 2011
Looks like excellent results already!
Thank you sir!
That looks awesome, what grits did you use? And did you strop it?
I went diamond stones 100-1000, sand paper at 1000, 1500, and 2000 then strops at 14, 10, 5, 3.5, 1, and .5 microns
Ok thanks, I just picked up a W/E last week along with a wilson combat small starbenza so I'm kind of in the same boatBlue scotch tape I'll take a picture in a minute and post it for you but I cut the sand paper to the same size as the stone on the paddle and the wrapped the top with blue and the pulled as tight as I could and tapped the bottom
On sebenza I haven't touched it with stones just strops and it turned out nice, I have only done three knives on my WE and it is breaking in awesome I can't wait to see its maximum potentialOk thanks, I just picked up a W/E last week along with a wilson combat small starbenza so I'm kind of in the same boat
Good job! I'll trade you an Edge Pro for it..![]()
At the rate you are going I predict you will be offering professional knife sharpening services in about a week. At minimum this thread has motivated me to get off my butt and start taking knives to a very sharp/mirrored edges. Thanks for taking the time to share the photos/progress reports.
Okay, just got done with my kershaw 1760 with cpm154 blade steel started at 4:45 today all i can say is there is going to be some awesome pics tomorrow, tomorrow I'm going to sharpen one of my custom knives with cts-xhp it should be interersitng because the cpm154 was a B**ch for real
Do you think it would go faster if you had the 50/80 grit stones? I'm thinking of picking those up
The scratches are there, just depends on the way I hold it in the light. my diamond stones aren't completely broke in yet so the scratches from the 1000 grit diamonds are pretty provident but the sand paper I use does a very good job at hiding them and polishing over them
I like the idea of attaching the sand paper to the ceramic stones.The cube is a must. I find I usually need to set up the arms with one degree of variation, e.g. 24 on the fixed side, 25 on the moving clamp side to be about equal. You also want to be careful with how you position the knife on the vise ... to avoid wider tips. It's easy to get a sharp edge. It's not easy to get nice looking, even bevels.
Also, when you are sharpening (not retouching) make sure you spend enough time with the coarser stones ... but be very controlled with the pressure you apply. Usually, let the weight of the stone do the job.
Once I get to 1000, I cut strips of 2000 3M auto sandpaper and tape them to the ceramic stones (which I do not like). These do a great job of producing a mirror.
