This is why I take this approach:
The plunge is perfectly symmetric, the edge is perfectly straight and centered and exactly the thickness I intended. Don't get me wrong, I'm not saying that my way is better or that I think I'm a better knifemaker because of it. I'm saying that, for my goals and priorities, there is literally no better way to do this.
Nathan
This is way cool, and as I have one of your great "pig stickers", I am enjoying this WIP even more. I do have a question -
Since you did the profiling "dry", is there a reason you did the bevels with coolant?
Thanks
Bill Flynn
I'm in school to be a machinist, so this thread is awesome!
I've been working how to cut bevels in my head for quite a while (knife nut in a machine shop...what do you expect lol), it is awesome to see how someone else does it.
It depends on the cutter and the cut. In this case the cutter in the video is just taking a spring pass and all the work has been done with a rougher. Once the finisher starts to leave a bit of a burr I move it down into the rougher's slot and put in a new finisher. At that point it is just getting broken in and it will perform well as a rougher in this application (endmills chatter less and are more durable once the very edge has been slightly worn). After that it gets put onto the shelf to be used as a rougher for profiling. When used as a rougher for profiling I keep the point down and out of the cut so once it is dull in that application it can still be used as a rougher for regular endmilling. After that it goes into the scrap carbide pile. The geometry of the cutter and the coating make it perform extremely well and consistently from cutter to cutter and you just don't get that kind of performance and consistency with regrinds. If it were a larger cutter I might send it out for sharpening but I'll frequently use inserted cutter bodies for larger cuts.Nathan, what do you do with the cutter once it's worn out after half a day's work? Does it get resharpened? new carbide teeth? recycled?
Love the thread, btw.
-Daizee
Excellent thread by one of the most talented, knowledgeable "Hack Machinists" I've ever had the pleasure of knowing. Your work is inspirational in every way - and second to none !
In regards to milling the bevels standing up as you've done on this piece vs. laying it down, and milling one side at a time with support on the back or bottom side, as was done with your Dagger. Or was it the Hunters that were milled one side at a time ?
Whatever the case, what kind of tool or workpiece deflection do you encounter in this type set-up ? Your excellent video shows one pass. Was that literally, a one pass per side operation, or did you need to make numerous passes to remove material that remained due to deflection ?
Again, excellent work Nathan ! Excellent !
:thumbup:
Dave! Where ya been man?
The hunters and dagger were surface milled. Surface milling is slow and leaves a messy finish but you can get any crazy geometry you want without any constraints. I take that approach when I'm trying to do something weird like wrap a hollow grind around a deep belly and keep the grind perpendicular to the edge or in the case of that dagger manipulating the grind to keep the point stout rather than a function of the width of the blade. The dagger was laying down, the skinners were edge up so I could do both sides at the same time.
I'm sure there is some workpiece deflection but due to limitations measuring a tapered work piece, there isn't any that I can measure. That video is short to show folks what it looks like. In reality there are roughing passes and a tool change to the finisher. There are three steps down, two trajectory passes and then that finish pass with a fresh cutter. I experimented with milling in the conventional direction rather than climb milling to reduce deflection but found it made no difference in this application.
