The first two are right, but...
Thanks! I edited my post to point to yours.
Ok, I drove an hour and a 1/2 today to Cabelas just for the sole purpose of purchasing one of these. I have it and love the look and feel of it. I have not used it yet! Everyone always says "practice on your junk knives." Unless I get a butter knife out of the silverware drawer, I don't have any of those. I don't have a large collection of knives, but what I have are nice and quite valuable to me. I have a couple Busse knives which are the biggest reason I bought this sharpener. As far as pocketknives go, I usually only have the one that I carry. When I get tired of a EDC knife I usually buy a new one and give my old one to a friend or family member. Second hand knives doesn't sound like much but, usually it is a big upgrade to the person that receives it!
I have been watching internet videos all evening and probably will wait until tomorrow to try her out. Does anyone have some good tips or tricks to keep me from messing up, or just help out? The first knife I am going to try is my old standby Spyderco Black Pacific Salt. If that goes good, I want to put a killer edge on a Busse muddy active duty that I have only made duller in all my previous attempts at sharpening!
Thanks to everyone!
Randy
Just go for it. If anything gets screwed up, the WS is capable of repairing it as your skills improve.
I'm lefty too. I've watched a few videos.
From the guys that own one, is there any reason you can't just turn the machine around and use it left handed?
It looks like you could in the videos I've watched. But maybe I'm missing something.
Anyone want to give it a try?
'Couple of things I've noticed since getting used to it. I can get almost all my blades to shave but not quite ready for stropping. After I mess around with every grit I have, the blade still needs a few strokes on a fine steel or ceramic before stropping. I don't know if it's just my technique or the limits of the belts. I'm not complaining about buying it though, it's worth every. penny.
The other thing is that when I set it to 20 degrees, it actually measures a little moe than 23, then if you apply enough pressure to detent the belt, the "final" edge will be one or two degrees steeper yet.
I picked up a Work Sharp Ken Onion Edition this weekend and tried it out on a set of inexpensive kitchen knives. Honestly, I wasn't totally impressed with the results. While the knives were sharp enough to easily slice through phone book paper, they weren't hair-shaving sharp. While that is good enough for basic kitchen knives, I wanted something more for my folding knives. I used only the recommended belts (X65, X22, and X4) and a 20 degree angle setting on the angle guide. I experimented with different amounts of pressure, different stoke speeds, increased number of strokes, and freehand, but I couldn't get any better results. I was expecting the same or better results than what I am able to achieve with a Spyderco Sharpmaker (with coarse, medium, and fine triangle rods) and was disappointed.
As for the angle guide, I definitely recommend applying some masking tape to protect blade finishes. I found that abrasive material built up quickly on the surface of the angle guide and the blade and caused a decent amount of scratches along the sides of the blade where the blade made contact with the angle guide during the stroking motions. I'd definitely be wary of using the angle guide with my more expensive knives without first applying some masking tape. I think the masking tape suggestion is mentioned in the user's manual, I simply chose to ignore it for my testing.
I also want to mention that I had some slight difficulty in maintaining a precise even grind when comparing grind height from one side to the other. The amount of deflection allowed on the belt is greater (and easier to deflect) on the trailing side than it is on the leading side. Though the grind was consistent along each side of the edge, I found that I had a tendency to put a slightly wider grind on the left side of the blade versus the right.
What I was impressed with was the ease and speed in which I could get a knife to the level of sharpness that I accomplished. On average, it literally took no more than recommended number of strokes per belt, at the lowest speed setting.
In the end, I'm still more comfortable with the Sharpmaker than the Work Sharp. I'm currently trying to decide if I should continue trying to find a technique for a sharper edge on the Work Sharp or just return it (with a fresh set of belts, of course).
