Pete chooses edge retention as the key criteria to measure folding knife steel.
Is is, only if you are only interested in edge retention. Most of us have wider expectations out of our knife steels.
There have been no defensive personal attacks. Just people who disagree with the points you have been making throughout this thread.
For folks who don't want or expect to be disagreed with, I always suggest a blog.![]()
I guess if you only cut sisal rope.
All that tells me is that heat treat is just as important as steel type when it coes to performance.I wrote the post to try and get a conversation going not to insult anyone. The list is from "Cedric & Ada Gear and Outdoors" who is on YouTube (from Australia) and he does cut tests. He is well known and those steels were from the very bottom of his list.
Knife News also ran an article on how bad/good budget steel is.
The cut tests:
KEY
Steel(Special), # of cuts knife #1 - Manufacturer #1; # of cuts knife #2 - Manufacturer #2
CPM REX 121(UNLEASHED TO THE MAXX - 13dg 3000 grit edge), 1300+ - Creely Knives
CPM REX 121(UNLEASHED - 17dg 600 grit Lansky edge), 925 to 950 - Creely Knives
M390(UNLEASHED TO THE MAXXX, 13deg/12deg per side), 550/810 - Steel Will
Maxamet(UNLEASHED - 17dg edge toothy), 810 - Spyderco Manix 2
M4(UNLEASHED - 15deg edge, 600 grit KME toothy/coarse edge), 700 - Spyderco Mantra
Vanax Superclean(1.55% Nitrogen/3.50% Vanadium Steel)(17deg KME Mirror Polished Edge), 680 - Shannon Labs Knife 60HRC
CTS-XHP(UNLEASHED TO THE MAXX - 12DEG/SIDE, 1000 grit finish), 600 - Cold Steel American Lawman
Maxamet, 563 - Spyderco Manix 2, 20 degree edge
LC200N(UNLEASHED - 16deg edge, 160,000 grit KME polished edge), 550 - Spyderco Slysz Spydiechef
CPM 10V(UNLEASHED - 17dg edge toothy), 550 - Spyderco Fahrid K2
Vanax Superclean(1.55% Nitrogen/3.50% Vanadium Steel)(17deg 600gr Coarse/Toothy Finish Edge), 550 - Shannon Labs Knife 60HRC
Z Finit (LC200N)(0.50% Nitrogen Steel)(17deg KME Mirror Polish Edge), 525 - Shannon Labs Knife 60HRC
S110V (UNLEASHED - 17dg edge) 500 - Spyderco Para 3
M4(UNLEASHED - 15deg edge, 160,000 grit KME polished edge), 500 - Spyderco Mantra
CPM M4(UNLEASHED - 17dg edge), 489 - Spyderco
K390(UNLEASHED - 17dg edge), 480 - Spyderco
ZDP 189 (UNLEASHED - 17deg edge), 480 - Spyderco Dragonfly 2
CPM 4V, 475 - Bark River Knives, Kephart 5
S90V(UNLEASHED - 17dg edge), 440 - Benchmade Altitude
M390(UNLEASHED - 17dg edge), 440 - Steel Will Cutjack
LC200N(UNLEASHED - 16deg edge, 600 grit KME toothy/coarse edge), 430 - Spyderco Slysz Spydiechef
M390(UNLEASHED - 17dg edge), 425 - REPLACEMENT Steel Will Modus
HAP40(UNLEASHED - 17dg edge), 415 - Spyderco Dragonfly 2
N695(UNLEASHED TO THE MAXX - 12DEG/SIDE), 410 - "Cudeman MT-5"
Z Finit (LC200N)(0.50% Nitrogen Steel)(17deg 600gr Coarse/Toothy Finish Edge), 390 - Shannon Labs Knife 60HRC
CPM 10V, 389 - Spyderco Fahrid K2
ZDP 189 (Factory Edge), 380 - Spyderco Dragonfly 2
Cru Wear(Polished Edge), 375 - Creely Knives
CTS-XHP (UNLEASHED - 17dg edge), 370 - Cold Steel American Lawman
CPM 20CV, 351 - Benchmade Griptillian 555-1
Cru Wear(UNLEASHED - 17dg toothy edge 600 grit), 350 - Creely Knives
VG10(UNLEASHED TO THE MAXX - 12DEG/SIDE), 340 - Kizer V3
ZDP189, 336 - Spyderco Endura
M390, 334 - Lionsteel TRE; 400 cuts at 20 degrees on mirror polished edge - WE Knives 620j
S30VUNLEASHED - 16deg edge, 160,000 grit KME polished/mirror edge), 330 - Benchmade 940
CTS 204P, 321 - Spyderco Southard
ELMAX (Unleashed), 320 - Microtec DOC (20 degree mirror polished edge)
HAP40, 300 - Spyderco Dragonfly 2
Z Finit (LC200N)(0.50% Nitrogen Steel)(13deg Tormec 1000 Grit Edge), 300 (edge did not hold) - Shannon Labs Knife 60HRC
Vanax Superclean(1.55% Nitrogen/3.50% Vanadium Steel)(20deg Worksharp Edge), 300 - Shannon Labs Knife 60HRC
CPM S110V, 295 - Spyderco Paramilitary 2; 281 - Spyderco Manix 2
S35VN(UNLEASHED - 17dg), 295 - Cold Steel Recon 1
SGPS, 291- Fallkniven U2
BOS S30V(UNLEASHED - 17dg Tormec 1000 grit), 290 - Bucks Paul BOS Heat Treat, Vantage Pro Mini
3V(UNLEASHED - 17deg edge, 160,000 grit KME polished edge), 290 - Survive Knives
CTS 40CP, 285 - Strider SNG
CPM M4, 280 - Benchmade Contego; 224 - Spyderco Mantra
CPM S90V, 278 - Spyderco Native 5
S30V(UNLEASHED - 16deg, 600 grit KME toothy/coarse edge), 275 - Benchmade 940
S30V (UNLEASHED, 17deg, Polished Edge), 260 - Spyderco Sage
K390, 242 - Spyderco Police 4
CTS XHP, 242 - Cold Steel Broken Skull
3V(UNLEASHED - 17deg edge, 600 grit KME toothy/coarse edge), 240 - Survive Knives
ELMAX, 236 - Zero Tolerance 0562
Z Finit (LC200N)(0.50% Nitrogen Steel)(20deg Worksharp Edge), 230 - Shannon Labs Knife 60HRC
LC200N, 226 - Spyderco Spydiechef
Vanadis 4, 225 - Zero Tolerance 0180 (???? 4V?)
S30V(UNLEASHED - 17dg Tormec 1000 grit), 220 - Benchmade 940
14c28n(UNLEASHED TO THE MAXX, Tormek 12 degree edge), 215 - Ruike P801SV
CPM 3V, 209 - Cold Steel Master Hunter; 198, Bark River Bravo 1 LT
CPM S35VN, 198 - Kizer Gemini; 194, ZT0220; 187 - Reeve Sebenza
3V, 195 (20 Degree edge) - GSO 4.7
A2, 191 - Bark River JX6 (BRK does A2 right)
RWL34(RHC 59), 186 - Foolhardy Knives
S30V, 185 - Leatherman Charge TTI
S35VN(Factory Edge), 180 - Cold Steel Recon 1
Acuto 440(17deg KME Mirror Polished Edge), 180 - Tangram Santa Fe
Laminated CoS, 176 - Fallkniven PC
CPM S30V, 175 - Benchmade 940; 190 - Spyderco Sage
1095(UNLEASHED TO THE MAXX, Tormek 12 degree edge), 150 - Farm and Field knife, 58 to 59HRC.
154CM, 150 - Leatherman Charge Plus
1.4116(4116)(UNLEASHED TO THE MAXX - 13DEG/SIDE), 140 - Ontario Wraith
Aogami Blue Steel(UNLEASHED 14 degree edge), 140 - Higo No Kami; 210 - Higo No Kami
8cr13mov (UNLEASHED TO THE MAXX - Tormek 12 degree edge), 135 - Kershaw, Atmos by Sincovitch. Edge rolled.
NIOLOX, 135 - Lionsteel T5
154CM, 124 - Leatherman Skeletool CX
D2, 120 - Ontario Rat 1 (Ontario does D2 right)
VG10, 115 - 17 degree polished edges, Spyderco Delica
CTS BD1, 112 - Cold Steel Voyager
CPM S35VN, 109 to 113 - ZT 0909 (TWO TESTS)
BDZ1(UNLEASHED), 111 - Gerber Strongarm
01, 109 - Tindall Knives Sawtooth Hunter
AEB L, 108 - DB Blades Custom Knife
Sleipner, 105 - Lionsteel SR11
14c28n, 105 - 17 degree polished edges, ? unknown knife
N695, 100 - "Cudeman MT-5"
80CRv2, 100 - Terava Jaakari puukko
Infi, 90 - Busse
X12MF, 90 - Kizlyar Fileen
Acuto 440(19deg Factory Edge), 90 - Tangram Santa Fe
14c28n, 88 - Mora Garbera
1095 Cro Van, 87 - Ka Bar BK7 (better than std 1095)
N690co 87 - Spyderco Pingo
12C27, 85 - Greystone Custom Knife
3V(Factory Edge), 85 - GSO 4.7
VG10c 83 - Kizer Dukes; 75 - Spyderco Delica; 74 - Fallkniven F1
Ceramic, 80 - Savannah, Kitchen Knife
L6c 80 - Svord Peasant
420HC (UNLEASHED), 80 - Gerber Strongarm
Acuto 440(20deg Worksharp Edge), 80 - Tangram Santa Fe
440C 77 - Lionsteel Mini
BDZ1, 75 - Gerber Strongarm
440C, 75 Kizlyar Hero; 70 - Kizlyar Ute
1095, 75 - ESEE 4; 69 - SCHRADE 42D
VG1, 73 - Cold Steel SRK
9cr18mov, 72 - Freewolf Knife
14c28n, 71 - Real Steel E571
Case Chrome Vanadium, 70 to 77
D2, 67/70 - Viper Keeper
4116, 67 - Cold Steel Bushman
BOS 420HC, 67 - Buck vantage select
C75, 66 - Opinel
Case Tru Sharp, 60 to 65
AUS8, 60 - Al Mar Facon; 58 - Ontario Rat 1; 52 - Cold Steel Kobun
5160, 59 - Ontario Bushcraft Field
8cr14mov, 56 - Tonife Luminescence
12c27mod, 55 - Opinel
AN58, 53 - Nieto Pegaso
440c, 53 - Ganzo Gsomething
440B, 50 - CutCo KA-BAR/Becker
420HC, 50 - Gerber Strongarm
M390, 50 to 100 cuts(5 complete tests), Steel Will Modus (BOGUS KNIFE STEEL)
420hc, 44 to 60 - Leatherman Surge; 48 - Gerber Strongarm
8cr13mov, 48 - CRKT NOMA; 39 - CRKT Swindle
420 J2, 40 - Buck 311
440A, 38 - Becker Remora
5cr15mov, 37 - Gerber Index
Victorinox, 36 - Explorer
7cr13Mov, 35 - Bear Grylls Knife
Cast Iron, 20 - Amazon.com Cast Iron Kitchen Knife
???, 9 - Z HUNTER
???, 4 to 6 - Shit internet knife
300 Stainless (?), 3 - Butter Knife
It's pretty technical. Not sure if a dog would understand.What does UNLEASHED TO THE MAXXX/UNLEASHED TO THE MAXX/UNLEASHED mean?
You're right. YouTube is missing a commentator.Posting on Knife News's site or on Cedric and Ada's Youtube page might also be good choices.
I believe I can clarify the issue for you. You did not ask a simple question, or any question at all. You made a rather argumentative statement in the thread topic:WOW! The personal attacks are off the hook. You people need to cool off.
I asked a very simple question, that does not require all of the defensive statements that I am having to put forth.
Wait, so wait a minute. You came in here, posting the opinions (backed by some subjective tests done by someone else) to state your position...that's really just someone else's position? I mean, I knew this was the case, just wasn't sure whose opinion/list you were parroting.
A good rule of thumb, by the way, is to make your source known.
Anyway, ok. Cool story. I mean, the logic flaws here are pretty bad. You see that, right? Steels that can't measure up in extreme cutting tests against super steels doesn't make them bad. That's like being saying donkeys are worthless because they aren't as fast as race horses.
Come on, man.
OK, well we can use Ankerson's list if Pete's from Cedric and Ada is no good.
Ankerson said the following are "Low-End Steels":
420J2
440A
5cr15mov
7cr13Mov
AUS-6
Cast Iron
Agree or disagree?
420J2
440A
5cr15mov
7cr13Mov
AUS-6
Cast Iron
Agree or disagree?
I have one karambit in Aus8, and I'll not be buying any more knives on that list. There are dozens of better steels and by supporting companies that turn out knives in bad steels, we are cutting our own throats.
If we stick together and buy decent knives, steels across the board will improve, and price will not rise.
Both of these will cut just fine for someone who needs a knife for knifely things (like cutting stuff). Soooooo........? How can you claim one is better than the other, to someone who just needs a knife to cut?
Why argue over other people's arguments?OK, well we can use Ankerson's list if Pete's from Cedric and Ada is no good.
420J2
440A
5cr15mov
7cr13Mov
AUS-6
Cast Iron
Agree or disagree?
Or to someone who isn't only interest isn't edge retention?
To claim steel X has better edge retention than steel Y, and that makes steel X better is naive.
