Ill take cast iron over Unknown blade steels. lolAlso, for the record, I'm still awaiting someone, ANYone to tell me about their experience with a "cast iron" knife.
"There I was, skinning this Saber Toothed Tiger my village and I had successfully hunted down..."
This is confusing because the thread title is worst three but the the list has seventeen items.
Is it that out of list there are three ones worst for knives? Cast iron is one for sure. What are the other two?
Does wrought iron tickle your fancy?Even then, I do not believe "cast iron" is actually a steel.
OK, lets hear what you think! I try to NOT buy knives made from these steels.
420J
8cr14mov
8cr13mov
5cr15mov
7cr13Mov
My theory is that the grains in wrought iron will work like nano-tubes greatly enhancing the desirability of said knife.Sure, as a nice trellis. Maybe a stair bannister?![]()
Like I said. Pretty technical.Standard worksharp edge test (20 degrees micro convex for most tests. 17 degree edges is typical for UNLEASHED tests) unless otherwise noted. The test counts the number of cuts to very abrasive 1 inch thick sisal rope. UNLEASHED TO THE MAXX, Tormek 12 degree edge is not for everyone. The steel edge will roll.
Heat treat is paramount really, condors 1075 is damn impressive and IMO better than pretty much anything ive tried for chopping.
440c was a super steel years ago. Ive used it to great effect, not as good at chopping but it holds a decent edge. I have a machete made from 420 hc that seems fine too. 5160 is pretty much the standard for choppers too.
I dont like 3cr whatever that kershaw uses in its lowend stuff, its pretty soft.
I t comes down to useage, i watched a youtube vid about a guy bagging on a Higonokami because the edge rolled while batoning. Its basically a straight razor, why would you baton with it?
Tommy, without going to Google up someone else's answer to regurgitate as your own, can you tell me which of the following two are better:
- A beautiful S110V Spyderco PM 2
- A beautiful Buck 110 in 420HC, and an inexpensive ceramic rod to keep it sharp
Both of these will cut just fine for someone who needs a knife for knifely things (like cutting stuff). Soooooo........? How can you claim one is better than the other, to someone who just needs a knife to cut?
I think you know the answer.
Did he say Never Buy! and make this claim about them?
I use all of my knives for self defense, so I'd take the S110V.
NO. I ASKED what steel would you never buy and then offered up the ones that I would not buy. It's pretty simple actually.
And from your comments, it looks like you would buy anything, and that is fine by me. That should really have been included with your first and only post.
