Originally Posted by bearcut
First is the Speedsafe system. On some knives I dont mind it, but on a hard use / survival type folder, I dont want or need an assisted opening mechanism. Had Kershaw seen fit to offer that knife without the Speedsafe, I probably would have bought one. If you like the Speedsafe system, then this will not be an issue for you.
I agree 100% :thumbup:
If you don't like the AO then you can just remove the torsion bar.
Are you saying a renowned design like Ken Onion would not have a well thought out knife? That's hard to believe. Although I did get a bit of a chuckle when you used the term "professional", but we won't go there.
You can remove the Speedsafe (& it is easy:thumbup: ), but in this case the 0301 will have an extremely low blade retention, because it has not a detent in the blade.
Check this topic to see for yourself, what I' m talking about:
http://www.bladeforums.com/forums/showthread.php?t=616055
As you can see in this link:
http://www.kenonionknives.com/past_knives.htm
the 0301 it is a design of Ken Onion
I think that the 0301 is an awesome knife, almost perfect (...damm detent) and it is amazing how the frame-lock is consistent in this knife, it is by far the best frame-lock I ever seen, fit & finish are superb for a factory knife (take a look at the titanium liner) & the price is right for the quality (especially here in Italy, where the prices are a lot higher than USA prices
, so we have to choose wisely).
The ZT 0301 is an example of extremely high quality folder and it is a knife that you will use to judge any other fullsize frame-lock.
The ergonomics of the knife are also outstanding :thumbup:
...but if you want to have a folder for "heavy duty" work I will suggest you a Manix (the ZT 0301 or other well build frame-locks are OK for general-medium use IMO), only for the fact that I consider the front-lock (with choil) more reliable than frame-locks (any frame-lock), an other interesting lock is the Tri-ad lock of Cold Steel, it is a sort of front-lock with a stop pin, sounds interesting to me.
Liner-locks IMO are not compatible with the "heavy duty" concept, I not trust liner-lock even for light duty works, I prefer a slipjoint at that point (no locks or strong & reliable locks, nothing between).
