00ChevyScott
Basic Member
- Dec 3, 2010
Yeah, that'll chip out a blade. Think about it, you're applying a levered force to only the edge of your blade. It'd be the same as putting your cutting edge against that counter and twisting into it as hard as you can. Honestly, 1000's of popping zip ties... I'd say that ELMAX held up like a champ.
If you're gonna use it like a prybar.... get a prybar.
If you put a little more of the blade through and rotated the knife counter clockwise (so the tip is resting against the fastener end and you slice through the tie on the right) you'll be using the blade edge in the way it's designed for.
I meant 1000s of times with all sorts of knives. Not this one in particular.
