- May 27, 2012
Wow, this thread makes me feel a lot better. I put a dent in my edge, and was bummed. From this thread it seems like a pretty common thing.
I'd like to know the details... I've been looking at this blade for a while and I find it hard to believe that a $260 knife is going to perform worse than any knife I have ever used in my life. A plastic zip tie did that? I've never had a knife that couldn't handle a plastic zip tie. To be honest, it looks like you were trying to cut it like a pair of wire cutters(short damaged area instead of longer dull spot) instead slicing it like a knife is designed to be used. If that's not the case, then I apologize. I would NEVER buy a knife that couldn't handle cutting a plastic zip tie. I laughed out loud when I read zip ties being one of the worst things to cut... I use to use a Leek at work to cut heavy duty plastic strapping(far worse than zip ties...) all the time. Sure it would dull, but the edge never rolled and it certainly didn't chip...
Heavy zip ties are much harder to cut than plastic banding. I cut both all day. It does not matter how good, thick or thin the steel is. If you start a cut on a heavy zip tie and torque the knife wrong it will damage the edge. Softer steel will roll easily even on a straight cut. Tie edges not trimmed properly after being cut are like razor blades and will slice the crap out of you. I have scars 10 years old from getting cut from improperly cut tie ends. We even removed a vendor who refused to trim the ties on material they sent into us. We use small wire snips to cut the ends flush with the fastener. The fix for the edge is an easy one but will take time with a sharpmaker.
mines cut though ty-raps, zip ties, wire ties, chicken wire, very hard cured woods, 3 layers of 2-ply dirty cardboard and the most i've had was a micro chip you couldnt even see and that was from the chicken wire, all though it did chip when it came into contact with some bone of a very aggressive gopher my dog had cornered (not the best tool for the job but hey its what i had on me) that took a few mins on a 1200 grit DMt stone to work out (i find it funny i didnt even have to use the course stone)
Gopher part made me smile. :thumbup:
Seriously?
Knife-fighting a gopher?
This just gave me a headache.
i have a no mercy policy for gophers after they ate 150lbs of my potatoes and 75lbs of my beets, if knife is all i have to kill them with i will use it .
They also ate all your capital letters.![]()
Dude, give the guy a break for Tfrg sake.
