Technically, it depends on a few things - thickness, stiffness of the material, etc. You keep oversimplifying things to a point where you're, at best, misleading. Edge thickness does in fact have an effect on flexibility. If a knife is flat ground, as most kitchen knives are, that thin edge doesn't just magically appear. Material has to be removed to taper down to that measurement, material from the whole height of the blade. So you can argue about the level to which it's a factor, but you cannot state that it doesn't have an effect at all.
The flexibility of the different steels at such stock thickness is so similar that it is
irrelevant to the discussion. Flat-ground knives are triangles in their cross-section, the distribution of mass/support in a triangle is weighted toward the spine's thickness to an increasing degree depending on the bevel angles. Like you said, the thin edge has to get there somehow. The effect of edge-thickness on blade flex for a 1" wide blade is
so small compared to the stock thickness that, unless the thicknesses are practically the same, the edge-thickness is
irrelevant to the discussion. It's like an I-beam (as you should know, being an engineer?) - what relevance does the thickness of the thin inner-portion have on the stiffness of the beam
vs the wide edges? In order to begin bending the thinner section, one must overcome the much greater stiffness of the thicker section(s) as stiffness is cubically related to thickness. For example, if the spine is merely 2X thicker than the edge (as in my Marttiini example, 0.040 vs 0.020), that means that the stiffness at the spine is
8X that of the edge - relevance ratio 8:1. If the difference is greater, say 9X thicker like the Buck, then the spine stiffness is
729 X greater than that of the edge - relevance ratio 729:1. This is not "over-simplifying", this is establishing
relevance.
You mentioned that one set of blades were thin enough to flex vs the other were not, I simply pointed out that difference has to do with their stock thickness NOT their edge thickness (as illustrated above) and only the
latter has to do with durability of the edge. I illustrated the point by giving an example (and another has been given) of thin knives with thick edges vs thick knives with thin edges.
In any case, I mentioned it because it demonstrates how they're drastically different knives. The difference between the two is obviously apparent in use...
..I've previously covered the edge thickness and angle.
I am glad you measure edge-thickness, not everyone gets the idea so I apologize for belaboring that.
The only difference under discussion is
edge durability which has nothing to do with blade flexibility or stock thickness, only edge geometry. You mentioned giving each the same microbevel angle but did not provide the edge-thickness of each nor the depth of edge-damage sustained. I am trying to get a clear picture of the edge-geometry of each. Were they the same or not? Giving a 15-dps microbevel to my straight-razor (already <0.005" behind its 8-dps bevel) does not make it more durable than my normal paring knife which, as it happens, is much thinner at the spine and so is more flexible. The paring knife is thicker behind the edge, this allows it to endure more stress (abuse) than the razor - they don't necessarily have the same edge-geometry despite that microbevel because (ab)using the razor-blade in similar fashion to the parer could result in damage
beyond the microbevel. My suspicion was that the same was true of your knives - the VG10 blades thinner (and therefore "weaker") at the edge and so more prone to damage despite the same microbevel angle as the others. If the VG10 blades are NOT thinner, or damage was within the microbevel, the point is moot.
I wouldn't say that VG-10 is giving me difficulties, I simply had to adjust my sharpening and reformulate my expectations. Again, I'm not saying one steel is better than the other in a vacuum, I'm saying that one steel is more appropriate than the other for specific use cases with specific knives. And for our use case, going to VG-10 on a select few of ours knives was actually a downgrade.
What we're losing sight of is practicality...
IF the knives have the
same geometry and one steel is performing better than the other in a given task, then that steel is absolutely better than the other. If VG10 at 60-61Rc requires a thicker geometry (and correlated lower cutting efficiency) to provide the same level of durability against the stresses it will encounter, it is worse steel 'practically' speaking at that hardness. That's what you mean, right, choosing the right tool for the job? Ceramic blades are capable of taking the
finest edges and providing
supreme edge stability (hence their preferred use in industrial equipment)... but they can be fragile if "mis-used" and since most kitchen knives
are mis-used the practicality of ceramic blades is low for most users (not to mention sharpening concerns). Perhaps the VG10 would be more durable/practical at lower hardness (
if toughness increases, which is not guaranteed), but then why bother with it? What would surprise me is if the steel
type rather than the hardness and geometry is what is making a difference as I very-much doubt that 1.4116 is all that much tougher than VG10, just softer so that it readily deforms where VG10 (at same geometry) holds firm (hence its use in so many popular spydercos). *shrug*
http://www.cliffstamp.com/knives/reviews/deerhunters.html
Back on topic, the abuses to which soldiers submit their knives is so significant that it overshadows the minutely different levels of toughness provided by a lot of steels. To encounter such stress, the maker must provide a strong geometry first and then select a material that can achieve an appropriate level of edge-hardness (>56Rc?) without compromising its durability at the geometry selected. I would guess that 12C27 and 420HC are not as tough as L6 or 5160 or S7, but at the geometry required to sustain the level of stress to be endured, those differences may not mean much practically speaking. These are corrosion-resistant steels and maybe provide a harder edge and a soldier might not see any benefit from selecting Elmax or M390 instead... The comment was made on Jim's rope thread that Spyderco left a
lot of edge-retention performance behind when it built knives of premium steels with such thick geometry (>0.020" behind the edge)...
