Yes, thereby making AUS8 knives that were previously quite acceptable to now be crap. As soon as the XHP versions came out, the AUS8 blades dulled and rusted literally overnight. My Recon 1 ceased to be able to cut warm butter.
LOLing....:thumbup:
I hate when that happens!:grumpy: LOL!
So many good steels are rendered useless as soon as an improved version coms out.![]()
Wait. We have been told in this thread that 440C is better than AUS-8, and CTS-XHP is better than 440C.
So it is clear that the CTS-XHP makes a better knife than AUS-8 for all uses/users!
But it comes off as more of an opinion piece. 440C is better than all these select old midgrade steels because.......
Then you start to wonder why you chose the steels you did, and left out a lot of common steels used by big manufacturers and fixated on only a couple manufacturers .
Then you seemed to peak at S30v the big steel of 10 years ago. Both are good steels but again different steels are developed for different purposes. If I was doing something wet I'd used the S110v bladed knife in my pocket over the M4 blade in my other pocket.
And things that work for our granddaddies and daddies is a silly argument, they didn't have the options we do. I wouldn't go back to paper filing my taxes because my dad did, I wouldn't drive around in a car with no seat belts because my grandfather did. The advancement of technology is a good thing.
At the end of the day, considering what Buck (and Case Tru-Sharp) has done and continues do with 420hc, a lower carbon, lower chromium, no molybednum version of 440a with 0.3% vanadium added to give it a little extra umph in strong carbides, all in all they are ALL quality basic stainless steels in their own right when mixed, handled, and heat treated properly and with care to detail.
If I had to rank them,
420hc - 12c27 *push
440a - 7cr17mov *push
14c28n - Aus8 - 8cr14mov *push
440c - aus10 - 9cr18mov *push
*(from a metallurgical point of view, those groupings are the most similar in composition, but it's not to say necessarily one steel is better then the other or that one group is better then the other, but rather "IF I"; personal preference will ultimately dictate who likes what more, and anyone is free to prefer one over another as I too prefer certain ones over other ones. )
But again, ALL make a quality affordable blade steel when properly made by a company who knows how to handle a certain steel;
I think Cold Steel and their aus8, Kershaw and Sandvik 14c28n, Buck and Case both with 420hc, Boker Magnum and Boker(+) with 440a vs 440c, SOG, CRKT, Taylor with their 7-8-9cr-MoV's
familiarity with one over another can go a long way...
I thought that was pretty clear when I originally wrote it, but maybe it was worth repeating.
Anyone with in depth insight want to add or chime in, it is strongly encouraged, but i wanted to put together a somewhat short, (it's long, but for the amount of information packed in, it's actually pretty short), somewhat "laymen term" and understandable explanation of how some of your more basic steels compare to one another, as well as where 440c actually sits amongst them.
With apologies to Ken Warner.
There is no best steel. There are only best steels for: for certain geometries, for certain hardness, for certain applications.
If i had to rank them,
You intended to tell laymen how steels compare to one another.
I intended to point out to laymen that you cannot compare steels and rank them as you wanted to do. As I said earlier, feeding the myth that one steel is better than another is a dis-service.
You, of course, are free to spread the myth as much as you would like.
It is not a myth that one steel is better than another. A product is always a combination of intended use, materials, manufacturing, and sales that has to be a compromise. A knife, designed for a type of user or specific application, made by a company with specific capabilities and to be sold with a defined marketing strategy, at a specific price...there is probably a "best" steel.
Think of it this way. For Buck, 420HC is the best steel for a $30 hunting knife. They also use it on some of their high end fancy knifes. However, many customers have trouble paying $400 for a hunting knife (could be the same basic blade shape) that has 420HC. In this case the "best steel" may not be 420HC and it will have nothing to do with the performance of the knife at the intended task.
You have very poor reading comprehension skills...
Ha! See that marci! Turns out, you can't read! Or perhaps it was the massive walls of text.....
Seriously though, 440c is fine. I've had it in a couple blades. Worked great. Would I seek it out like I do my more preferred steels? No. These threads and posts putting it on a pedestal with folks foaming at the mouth and posting walls of subjective opinion as fact are getting tiresome.
Seriously though, 440c is fine. I've had it in a couple blades. Worked great. Would I seek it out like I do my more preferred steels? No. I use what works best for me. These threads and posts putting it on a pedestal with folks foaming at the mouth and posting walls of subjective opinion as fact are getting tiresome.
