- Dec 27, 2007
So then, if the 440 family of steels are a great steel, why is it that premium knife makers use other high alloy formulation steels in their high dollar products?
Marketing can also explain this.So then, if the 440 family of steels are a great steel, why is it that premium knife makers use other high alloy formulation steels in their high dollar products?
Ever hear about the Russian space pen? Same thingwhat the heck is a pencil?
Yes I know but Waterway is the only LC200N Spyderco knife fulfilling the criteria to be my diving (spearfishing) knife. A bare minimum spearfishing knife should be a fixed blade, should have a narrow point for deep and easy penetration to a fish skull, a full size handle, plastic/kydex sheath and should not make a man cry if it get lost. Mora SS companion covers most of these. A perfect spearfishing knife for me would be made of LC200N with a blade shape similar to waterway in which penetrates fish skull easily and offers utility (i.e. fish cleaning/filleting) possibilities. Plain main edge and serrated cutting edge on the spine and blade and handle length inch shorter than waterway with more compact sheath. But Mora SS companion would doAlso, do you know Spyderco has a series of knives much cheaper than the Waterway, using LC200N, the Salt series? Mora is great, but these are too, absolutely rustproof, serrated or plain edge, hawkbill, traditional shapes, whatever.
440 steel is fine, but no premium. The initial post asked to stop using 440C over 154CM, which is another steel of the same grade, a side grade, which doesn't make thing any better.So then, if the 440 family of steels are a great steel, why is it that premium knife makers use other high alloy formulation steels in their high dollar products?
What stainless steel blade stock does Rsandall-Made use for their forged blades?
I don’t know about the steel here but most kitchens where I grew up had themHere's a brand new knife in 1095. Barely got through one bag of potatoes.
I believe that you get it wrong a bit here. Nitrogen does helps in refinement, but Vanex and LC200N has very low amount of carbon, which already help to get finer carbides. The low amount of carbide also reflex on their lower wear resistance on Catra test. MagnaCut "secret ingredient", stated in Larrin's video, is more about Nitrogen than Vanadium.SS vs Carbon debate.
My understanding is (generally speaking) the chromium carbides in SS knives are tend to be larger than most other carbides which makes SS knives (having excessive amount of chromium carbides) brittle. But now we have SS knives with -nitrogen carbides (e.g. LC200N and Vanax) and vanadium carbides (e.g. MagnaCut). These carbides do not tend to be as large as chromium carbides making the toughness/ wear edge retention balance of these SS knives more or less similar to their Carbon knives equivalents. But yes, they are very expensive as a raw material and costly to heat treat compared to carbon knives.
randall uses 440b for stainless cause it can be forged...and they do forged blade making. not all knife makers do forging.......a lot of stainless its stock removal setups..So then, if the 440 family of steels are a great steel, why is it that premium knife makers use other high alloy formulation steels in their high dollar products?
I really didn’t know what they used just that they make very good knives.randall uses 440b for stainless cause it can be forged...and they do forged blade making. not all knife makers do forging.......a lot of stainless its stock removal setups..
randall could switch stainless but then would have to do stock removal methods and they don't do knives that way.
I'm no blacksmith or knifemaker....but I think it's not that it can't be done per say....... just different steels are harder to do than others....so cost and time issue. maybe also end results vs. effort applied. here's an article on forging and explains it in detail........And now for a naive or noobee level question"
what makes other steels unsuitable for forging?
What makes such steels desirable for use by non-forging knife makers over the 440 family of steels?
Here's my thought - if you don't like it, don't buy it.It's about time we finally can the steel, am I right?
People say it's all in the heat treatment. However
At the additional price point, you are better off buying serviceable 154CM. Thoughts?
o1 on carbon steel models and typically 440b for stainless.I really didn’t know what they used just that they make very good knives.
Ok, now a naive or noobee level question:
What makes other steels unsuasible for forging?
