I managed to get the guard and handle glued up and curing for the night. I was hoping to get this done by 10:00am this morning, but.......... I "chose" to spend most of the day installing a new toilet and bathroom floor instead.
I did spend about two hours this morning (pre-bathroom reno) fine tuning all joinery. Then, just for shits and giggles, I blued the guard with some Birchwood Casey Perma Blue that I was given by a hunting guide who lives up the road. I've never tried blueing and I like the look, so........the guard was sanded to 800 then given two successive coats of blueing, then polished to a nice luster.
I started the day with a young, but determined helper in the shop:
Shaping the spacer:
Its
a bit more "oval" than I wanted, but its a good shape and there's plenty of contact surface.
Cut away some stock:
Shape on the drill press:
Checking the fit.... yet again. Just a nice perspective to detect if everything's flush as it approached contact:
Contact:
The tang was sanded clean with 180 grit, then textured with a file. Everything was then deburred and given a good cleaning with acetone to await assembly:
The blade was given a final polish at 1000, as well were the spine and ricasso, then cleaned well and re-wrapped for gluing:
I usually have System Three around the shop. Its a good epoxy and I'm used to working with it.
The tang is coated with epoxy steel and the guard lowered into place:
The same is done with the spacer, then the handle block is fitted and press firmly in place. The handle block is then clamped in place until the epoxy steel is set. After ten minutes, the handle block is removed and the faces cleaned well.
I start by cleaning away the excess with a sharp copper wedge.
I'm looking for a nice smooth seam. I remove most of the bulk with the wedge, then use q-tips and acetone to clean it up. This side is almost there:
After I scuff up the inside of the tang slot with a broach and then clean it out well, I pour in some epoxy. Using a stir stict, I'll mash the epoxy about to get it into cracks and such, then pour in more. I use a bamboo skewer to poke around and get out any bubbles. I'll let that settle for a minute or so before inserting the tang. I also give the block face a coating of epoxy.
The tang and spacer face are slathered with epoxy being sure all the notches and crevices are filled in, leaving no air bubbles:
The tang is fully seated and the excess epoxy has been quickly wiped away. I don't mind leaving a small bead of epoxy around the handle/spacer seam. I just don't want any epoxy left to dry on the guard, so I go to lengths to get it good and clean:
And, finally.... after everything has been checked, and double checked for alignment.... its time for my gluing jig.
I'll leave as is it to cure overnight.
Have a great night,
Peter
