Cliff Stamp
BANNED
- Oct 5, 1998
Cliff, there is a difference between the ABS and PCC competitions. Only the latter admits all types of steels and makers.
Yes and what is the point you are making here? Are you arguing that if stock removal steels were allowed to be used then high carbide steels would dominate the ABS competitions? Are the tests used by the PCC more stressful, is the level of competition higher? Are the people who win the ABS tests being systematically outperformed by stock removal steels in PCC contests?
There is also a difference between doing very well and winning.
He has won, as have many others in very low carbide steels as hardheart has noted. As well, be specific, how much steel performance do you think is actually represented by the person who came in first and the others that placed? Will you even make the arguement that steel dominates user skill in those competitions?
And there seems to be a difference when Dan Farr says speed is good and when others say speed is good. You take exception to the latter and quote the former in making other points.
I was not referencing Farr's post to make a comment about speed being necessary, it was to show that 5160 knives can win in such competitions and to raise an issue about dynamic balance. I noted years ago that speed is necessary in a chopping knife when the wood is live and springy. Speed is however not simply determined by the center of mass of a knife and is strongly influenced by user strength.
As for my using a random kitchen knife to make judgements on kitchen knife steels, you use random production knives to make judgements on steels all the time.
When I know the steels and and the result correlate well to the several other hundred knives I have used and also match the materials properties, then yes, that will become a part of the information I will use to make judgements on that steel. Generally I would bound the performance by the extremes on the high and low end using a custom maker vs cheap production knife to do so.
Thus if you wanted to know how 12C27 performed then a $5 Mora will give you an indication of that, keeping in mind the hardness will vary from 50-60 HRC on such knives so try a couple at least. If you want to know the optimal performance then get a blade from Landes or a similar maker who specialized in the steel, or at least follow his heat treatement to get a 60/61 HRC blade with <1% primary carbide and minimal retained austenite to give near maximal edge stability.
-Cliff
