- Aug 1, 1999
That's the ABS competition which excludes stock removal (nonforged) knives. The Professional Cutting Competition is open to all knives and all knifemakers. ABS members also compete in the PCC.
Clearly, you are claiming greater skill and understanding of edges than the best of the knifemakers who are competing in these competitions.
Tai Goo is a wonderful bladesmith. He does not make competition cutting blades.
If you can do that 3V bending task with something else, do so and take photos.
52100 has 1.0-1.1% Carbon. 12C27M has 0.52% Carbon. 12C27M has 14.5% Chromium. 52100 has 1.5% Chromium. Don't look much alike to me.
Hardheard, I don't think the difference in the tests is the point here. The point is more that the use of CPM-3V, CPM-M4, etc. is precluded in the ABS championships, as they can not be forged (well, not really, that is).
It is like claiming that the Mini Cooper has won all races and not to mention that Ferrari's, Lamborgini's, F1 cars etc. weren't allowed to compete.....(not the best example, but I think it makes the point).
Hitting a rolling ping pong ball may require user skill, but cutting it rather than just deflecting it requires a very fine edge as does the paper towel ring cut among other tasks.
Certainly, Spruce isn't very hard.
Your claim that what you do is many times more stressful than what other people do to test their knives...
Your assertion that was merely a ruse by using an appropriate stump is cynical at best.
I didn't say Tai Goo's knives weren't high performance knives, but neither you nor I have a measure of how good they are compared with the PCC knives.
Being in German does make it a handy reference source for you though, since there is no easy means of confirming your quotations of what he's written.
I don't think you can just look at the winner's spot and say M4 is better.
What is the thickness and edge angle on the cutters? Is it significantly more acute than the profile I noted in the above?
Not when it is live no, when it is dead and seasoned for 5-10 years and it splinters leaving actual sharp edges it is different.
I noted that wood cutting described is more stressful than a static cut of a hardwood dowel because I have done both and know what edges are required for stability. This is not a claim, it is a statement of fact. I was also cutting dowels years ago so this is not something new.
It is also fairly basic physics because the dowel is much larger so the stress is lower and is a much more static cut whereas in the limb cutting the branches will bend and snap around the edge and after the first cut the edge will hit them off center.
To simulate that with a dowel cut, stick a bunch of dowels into a 4x4 at odd angles and then sweep them all off with one cut of the knife. It isn't clear to you that is much more stressful? Have you actually ever done the limbing work I described?
Why would you even assert that non-PCC knives are inferior anyway? Again, do you assert that the edges on his knives would easily roll and impact in use, yes or no? He uses the exact steels which you claim have that performance and he is known for very high performance cutting and sharpness.
.Of course all the guys forging using very low carbide steels whose knives run lathe martensite (which requires a low carbon content as plate will form otherwise) also make the same statement
All that means is that it is popular. Would anyone even argue with 100% confidence that the winner would even change if you switched knives. It is also not the case that all follow the high carbide = superior line, Thom has noted outspoken makers who prefer low alloy steels such as one rather well known one who is collaborating with Spyderco (Schempp).
Does anyone know what steel is used in a Fiskars hatchet? Also, do they make knives?
Ask one of the participants.
Are your edges convex?
"Sharp edges" on wood has what to do with how hard it is to cut?
When it is witness by others who attest it actually happened it becomes a statement of fact.
You're comparing a hardwood dowel with spruce, and even then the edge has to also prove it can perform the fine cuts in the contest. Not an apt comparison.
Hardly. I also note that you have slipped from "low carbon" to "low carbide". Which is it? Is O1 Low Carbon/Low Carbide? Which is 52100 REALLY? How about CPM-3V? 0.8% Carbon?
Since when is CPM-M4 "popular"?
There are GREAT low alloy steels, by anyone's measure. There just aren't any GREAT low carbon stainless steels.
Fiskars as a brand doesn't I don't think But they own gerber so maybe in a sort of making by association type thing.
My point is, could not references to grain size, carbide size & percentage, and push cutting edge retention be better understood by more readers everywhere, than the obscure term of edge stability? Is the use of all these redundant or obscure terms meant to
The standard edge on my wood cutting knives is 8/10:0.030"-12/14:0.015". ....What is the thickness and edge angle on the cutters? Is it significantly more acute than the profile I noted in the above?
Warren Osborne also said "At 58 rockwell [M4] will bend and will not break" and that even with a primary bevel ending at 17 thousandths of an inch at 62.5Rc would not chip out.
Toughness can suck; take S7 for example.
Thom, this thread as with the previous thread that was closed deals/dealt with chopping tasks. Even discounting my contention these steels are not strong and will roll easily even at high hardness, they are not wear resistant steels and I have some difficultly understanding why you would use them in any application that might entail cutting hard or abrasive materials or would encounter hard impacts as in chopping.
Also, I'm having some trouble heaping 52100 and L6 in the same pile with 12C27M and 420hc.
I certainly wouldn't give AEB-L higher marks than S30V in any application I know of, and I own Kershaw knives in both steels so I have some sense of what they offer.
S7 might be OK for a beater/chopper, but it certainly doesn't offer much wear resistance and it is suscepible to deformation. I doubt you'd want to put a very fine edge on S7 and cut something hard.
Are Forschner Cooking knives substantially better than Henckels Professional Grade knives?
I sense there is a belief that steels like S7 are new discoveries in the knife world. Nobody used them as recently as 5 years ago, and that wasn't entirely an oversight. A good number of makers tried them and didn't think they brought much to the table, not enough to stop using O1 or 1084 anyway.
Chopping with thin steel edges at high Rc's is what they do in the PCC events. That's why I keep mentioning it.
Chop a nail! If what is said about these steels is true, you can't do worse than with the lousy old 154CM blade in the pic above.![]()
