- Aug 7, 2007
Only problems IMO.
1) Stop pin too thin. And...
2) Pocket clip too small.
The stop pin is too thin/small. Would have been good if they had some titanium backspacer material (referring to the area, I know there is no backspacer) supporting the stop pin. As it is, the stop pin is weaker than the strength of the lockbar which makes this folder stronger in resisting closing/spine-whacks compared to opening/chopping forces. Either make the pin thicker or support the pin with some titanium, not necessary to grind away the support of the stop pin. Best to adopt both
The pocket clip is a bit short. Though it is pretty strong (thick little bugger) it would have been perfect is they could incorporate the Hawks Bros type clip for a folder of this level. The Hawk Bros pocket clips (one with a polymer ball bearing and one with a roller) enables easy insertion/extraction from pocket and does not mar the finish. However failing which a simple lengthening of the pocket clip is gonna improve aesthetics and pocket retention.
