Larrin
- Jan 17, 2004
The presence of cracking being around the perimeter of the blades most likely indicates an issue that occurred after steel production rather than during it. It’s not a coincidence that it just happens to be located there. It could be that the shearing was not the source but instead something that happened during heat treating, etc. My testing showed the heat treatment was good in terms of properties but wouldn’t necessarily show intermittent cracking. It could be possible we can figure out definitively what the issue was though I admit I’m not that excited about dragging out this thread for months.I promise that I'm not trying to be rude with my following statements, which I feel is necessary to say because I'm often misinterpreted.
To me it seems like faulty steel, plain and simple.
We see that ProCut performs quite well for other makers, and I'm not deeply educated on the matter but I assume that it has been tested successfully with both industrial and workshop heat treats. From what I understand,Crag the Brewer has also made successful knives from ProCut in different stock thicknesses, but please correct me if I'm wrong.
I'm assuming other makers have also successfully used ProCut in 3/16" stock, the same gauge Crag is having issues with, right?
And obviously sheared edges have never been an issue for me or most other knife makers, and I have never had a piece of steel to flake apart like a Pilsbury biscuit. Even if the sheared edges present some degree of an issue, I could see 1/8" of material in extreme cases, but not flaking on a false edge nearly 1" in from the sheared edge.
So, ruling out all of these variables, the only logical answer, to me, is that Crag has received bars of steel that are faulty. My best guess is that whatever sheet these bars were sheared from, something went wrong during the rolling process. To me, that would fall upon whoever processed the melts for Pops, who obviously need tighter QC, but I also think that since ProCut is a product created for and sold exclusively by Pops, that it would be good of them to make things square with Crag.
That's my opinion on the matter, and how I see it, but if I'm found to be wrong I'll gladly admit it.
With that being said, I agree that if the problem is seen by someone else it should be escalated to the steel manufacturer. They would have the facilities to investigate things with SEM, etc and should have a quality department for this kind of thing.
I’m sure Pops is handling things on the customer service side to help Crag the Brewer out.
