- Aug 21, 2014
use it and dont worryThanks again !
I think, I like how this one came out today.
Not sure if I should clean further. Seems just the right amount of character. What do you all think ?
Roland.
Roland.
I just finished up my first strip attempt on this guys larger brother. I was running out of daylight so I snapped a quick phone pic.Thanks again !
Roland.
think the grey layer under the colored layer is the decarb no?
wee bit of mineral spirits and some scotch brite will do that one a service
Shes purdy bro thats a forced vinegar patina and mineral oil wipe down !a
I think it looks okay but I was not sure if I should focus in on those darker areas along the edge.
Did you use the stripper over the logo or did you re-etch it first? I left the citri-strip off of that area until I could find the thread on etching.
Which if anyone has a link to I cannot seem to find it. I swear there was an in depth thread on stripping and etching but I have a learning disability
She got hand treatment with the scotch before the patina View attachment 1653365
Stripped my Axe Hammer today. Same color as yours afterwards,skyhorse , but used normal stripper ("Klean Strip").
Will send it to be bead-blasted.
Before Stripping:
After Stripping:
Thanks for sharing pics, guys. Given your pics, and my OCD, I had to do another iteration
Here is the result:
Here is maybe a new finding, at least for me:
We have this stuff at home, acid based, that we use to clean our airstream, and that I have used in the past to de-color/de-oxidize Hinderer Ti hardware.
This is what I used for the above, appears effective at removing decarb. Not sure how Res-C reacts to it, so I only used it on the blade. Use at your own risk, please.
The resulting finish is similar in color to Hinderer's Working Finish, which is why I included a Hinderer in the photo (pics are in the Californian noon sun).
Cheers,
Roland.
Good to see you postingI always have one or a dozen nearby, still love those INFI dimples!
Decarb cannot be removed without abrasives (ie. grinding it off to virgin steel beneath). It refers to metal that has lost it's carbon content to some degree, that product will not undo that damage. What it likely did was stripped the oxidation (scale) from the heat treat to look a bit cleaner.
I'm not really sure what all this means , most of my experience with strippers was learned during my misspent youth ?You don't know that. And neither do I, since neither of us is a chemist.
I can just report on what happened, which is the following:
- I stripped the DS6 (with original dark blue coating)
- underneath came out a dark coating, much like after stripping my Axe Hammer
..... - nobody here actually seems to know what that is. It could be decarb, or "blue-black oxide scale that forms at temperature above about 450C" (definition see https://www.bladeforums.com/threads/what-is-decarb.711078/#post-7792075)
..... -skyhorse 's report on stripping his INFI knife and leaving it neglected for a long time without rust forming is very interesting. The BF reports on "decarb" rust that I found refer to stripped SR101 blades
- I sanded the DS6 and got most of the "decarb" off (for the results see post #60, https://www.bladeforums.com/threads...strippers-lately.1784548/page-3#post-20772033)
- I dunked it in Alumabrite for several hours.
..... - it formed a black "goop" while doing it's chemical reaction; That goop needed to be rubbed off.
..... - underneath is a grey steel surface. The Alumabrite smoothened out the surface somewhat, my (fine) sanding scratches are gone.
..... - the metal surface is homogenous now, meaning the Alumabrite affected both the bare metal, and whatever remained of the "decarb" for example in the grinder's "chatter" line that you see on one side.
And that's it. Report complete.
Roland.
