Thanks man... yes in person it looks SO much better then in picturesThat is one of the most beautiful knives I’ve ever seen. Bad ass is probably a better description.
Was at 19dps and lowered the edge angle more... haven't measured it yet but I reckon its gonna be at 16.5. It cuts like a razor.... I will make a video
Yes good idea... I bought a second one.Cool, thank you for going to the trouble. The HR2 with the corrugated bevel actually has what is overall a convex shaped grind, so it should be a cutting machine with good edge geometry. I've been eyeing another one for myself before they pull them from the storefront. What did you do the finish with on that and can you elaborate on the sheath screws in place of eyelets?
So when you guys strip the coating off, do you leave the handles on?
Do you tape off the handle so that no part of the handle is exposed, only metal exposed?
Will stripper harm G10 or micarta?
(1) I prefer screws for maintenance. (2) the rivets are easy to drill out, and spacers/screws are cheap. (3) it's easier to sand/polish butt and tang when the scales are off - so I take them off.
That is popular when stripping but it leaves something to be desired personally. There's a reason Busse does not use these fasteners as it would be easy for them to use this method. Even older Busse that used what appears to be solid pins are in fact bolts that have been torqued and loctited and then had the heads sanded off to make them maintennance free and rock solid. They went away from that method for whatever reason and seem to have done so because of the strength of the flared tubing rivets being superior. Is this an issue for most use? Probably not but I say that because it is a thing worth considering.
I doubt the flared tubes are there for mechanical reasons. Just cheaper to install and support than standoffs and screws. I for sure will never break three quarter inch stainless stand-offs or the 10-32 screws that I use. And some Busse butts have shapes that make sanding difficult for me. To each his own, I guess.
The real question I have regarding drilling out the tubes : what sort of material is the current form of tubing made from? It seems the older stuff from over a decade ago may have been some sort of brass like materail. The new stuff seems to be something like soft stainless perhaps. Trying to find a suitable drill bit ...
Perhaps, I seem to remember something being said about vibration transfer as well. There must be a reason besides cost but who knows ultimately, unless Jerry wants to share his rational behind it we'll never know for sure.
Thank you Sir!Beautiful. Banned edges are terrifying. I don’t think it’s possible to describe how sharp Ban Tang takes a convex, must be experienced. That SHBM is perfect.
Did you use blue loctite for your MMD? That’s what I used.I doubt the flared tubes are there for mechanical reasons. Just cheaper to install and support than standoffs and screws. I for sure will never break three quarter inch stainless stand-offs or the 10-32 screws that I use (with loctite, of course). And some Busse butts have shapes that make sanding with scales installed difficult for me. To each his own, I guess.
I usually use red on one side, blue on the other.Did you use blue loctite for your MMD? That’s what I used.
I should’ve thought of that.I usually use red on one side, blue on the other.
