You obviously have a problem with reading comprehension. Rat
You remind of that saying that goes something like.
Who is more foolish? the fool or the person who tries to argue with him.
Once again you didn't answer my question. Do you know what MPI testing and shot peening is done for.
BTW, I never saw a troop throw away his weapon and start using an AK, If I did I would've reprimanded him severely. All my men kept their weapons very clean and I inspected them regularly.
I think that myth started back in 'Nam, where it may have happened. When a troop was unhappy with his weapon, he was more than likely to grab an M-14 or a shotgun, depending on where his Unit was going. If he was unhappy with the then new M-16.
From what I remember MPI is magnetic particle testing that can detect imperfections in materials. However from what I know it only detects surface imperfections an really can't tell you if a material is structurally imperfect beyond that. The Military has forever insisted on this as it is a part of the mil spec and they stick to it by the letter. But it has proven to be of little value as the grand majority of failures are due to imperfections or stresses in materials that occur far beyond the scope of MPI.
Shot peening from what I gather is impact preparation of bolts prior to heat treating which changes the grain structure in order to better prepare it for impact service.
However from what I've read these steps only weed out bolts that will fail pre-100 round mark and cannot make any promises beyond that.
You think because Colt uses these processes that it's an iron clad contract that your weapon will not fail. I can promise you that they can all fail and the Colt doesn't have an edge over well built ARs using good quality materials. And these processes does not mean that a weapon will last longer by any stretch of the imagination. Anything can break at anytime.
Answer me these four questions
1. Is Colt the most accurate AR-15 available?
2. Is Colt the most reliable AR-15 available?
3. Is Colt the most durable AR-15 available?
4. Are Colts any more user friendly than other ARs?
Then you would be incorrect as MPI testing show both surface and sub-surface flaws in the metal.
However even if you were correct, this still contradicts your original assertion that a non MPI tested firearm is just as good. Knowing whether there are flaws in the metal of your barrel and bolt, even if only on the surface is better than hoping, guessing or assuming.
Incorrect again. Shot peening, if done correctly, can extend the service life of a bolt up to 1000% percent. Yes, 1000%.
It does weed out sub standard bolts, but thats a byproduct. It modifies the mechanical properties of the metal to allow it to take far more abuse than an untreated bolt. Thats not to say that every shot peened bolt is going to outlast every non shot peened bolt or that they will never break. However if you have 100 shot peened bolts and 100 unpeened bolts, the results are going to be quite clear which lasts longer.
I never said that at all. Every firearm, glock, colt, HK, etc, can and has failed. Thats not the issue. The issue is which one is more likely to fail. The better parts that you use make failure less likely. It is without question that a shot peened bolt is better than an unpeened bolt.
It is without question that a barrel made of higher grade steel will outlast a barrel made of lesser steel.
It is without question that a company that MPI tests its rifles is going to have less issues with metal defects than one that doesn't.
Sure anything can break at any time. Sure colt has produced lemons. Sure M4's have failed in the sandbox. However none of these things are incompatible with the fact that colt makes the best factory AR's.
Again, head over to any of the AR forums, and talk to some of the certified armorers that post there. Colt is the brand with the least amount of problems.
Whether a standard shooter would know the difference I don't know. Clearly there are some custom AR's out there that would spank a factory rifle, but thats not the issue here.
2. Yes. Again, most reliable doesn't mean perfect and I've never argued that it has. However if you take 100 colt rifles and 100 brand x, colt will have less issues. Range reports, training classes and what armorers see bear this out.
3. Absolutely. The best parts and the best QC is going to make for the most durable rifle.
4. I don't see how they could be as they are all physically virtually identical.
Look, we're getting no where. And what's worse is that we're crapping all over the forums here. At this point we are making no positive contribution to this community. I like a good debate as much as any one else but we're spinning our wheels. You will never be able to make 80% of the AR community believe that Colts are better than most of the other top makers.
What you would rather do isn't the issue. The fact remains that both rifles need maintenance and both accumulate gunk.
Everyone heaps loads of praise on the AK because its reliable, and deservedly so. What they usually fail to mention is that its effective range is almost half that of the AR. You might have the more reliable rifle, but thats not going to matter much if you have to close an extra 250 meters to bring the fight... especially when the guy who brought the AR is shooting at you.
i dont know about the effective range being 2X better w/a AR vs a AK, the ones i have shot with iron sites are pretty close to each other, sure the AR is a bit better but twice as good? i dont think so.
From what I have seen at 300 the AK is pretty much maxed out. The AR can make hits reliably at 500+. This is due to the tolerances, but also the longer sight radius. Its not exactly twice as much, but having an extra 200 yards is a good thing in combat.
have you ever tried to hit something at 500 yards? with iron sites? i have and its not easy with anything
one things for sure ya wouldnt wanna get hit by that "maxed out" AK at 300 yards.
