BluntCut MetalWorks
- Apr 28, 2012
Edge geometry is crazily important, next is the blade profile, third is ergonomic. So it makes sense to start from the apex, give best care/sharpening & sculpturing. Bevel face length and bevel shoulder thickness need to optimize for given tasks (in full consideration of cutting material & technique/requirement)... so on to macro level.
Bodog, excellent quick delineation between usage goal/need: wear resistance & high apex stability:thumbup:
52100/1095/W2/etc... are fairly high carbide(mostly cementite) volume. While 3V (0.8%C) has lower carbide volume but mainly Vanadium Carbide (1-2um in size), actually provide as much or better wear resistance. Plus it has quite a bit of free-Cr ~7% for corrosion resistant (a little over half way to stainless).
All clean steels are high tech to me. A clean steel with high alloy & other non-Fe elements (lower Fe balance) is like an artist canvas with 'outlines' designated for certain arts, and given 'pre-mixed' colors palette. For the Elmax blade above, I had to break the 'outlines'/primary-carbides (that's right, a long soak at 2200F) and jumbled up 'pre-mixed'/MxCy tendencies. Essentially, as stated by others/posts, super performance is super. Knife makers/mfg need to use whatever steels to accomplish that super performance. A wider range of utility is better than narrow/single-task performer. Also bang/buck ratio is part of performance equation.
