- Oct 26, 2000
Welcome to BF Xiao!
Pretty much sums it up!DOUG APPLEGATE said:I Have Several Of Mr. Atwoods Knives And Tools In Both Ti And S30v. No Failures And No Complaints. Why Don't You Just Admit That He Makes A Damn Fine Tool And Quit With All The Scientific Bs.
We Buy Them Because We Like Them.
Actually, the original question was which version, (S30V or Ti), should the person buy. Since they are only made in those two versions currently, arguing that they should be in XYZ steel is, technically, out of scope.
...it is assumed that the question is based on wanting performance not an irrational attachment to X or Y
The "issue" was which version of the tool that is offered should be purchased: S30V or Titanium
It depends on the cost, or more importantly the profit margin. Phil Wilson for example a few years back was offering his introductory kitchen knives in AISI 420HC for ~$125-150, his S90V ones were significantly more expensive.Cougar Allen said:it certainly wouldn't lower the cost; steel is not a significant part of the cost of custom knives or tools.
It is a custom piece, any option should be immediate unless as noted there is an irrational attachment to the base choices. I have never seen a custom knife maker refuse to workout outside of the standard and I usually go well outside their starting options, often suggesting steels no one has used before.Trout Tamer said:...my own motivation for posting was merely to gain further insight into the immediately existing options.
And yet in another post you mentioned that it is costly for knifemakers to stock and switch steels. Which is it? Stock 48 different steels in 6 thickness options for every armchair metalurgist out there, or offer what you offer in the configuration you offer it for those who want it?It is a custom piece, any option should be immediate unless as noted there is an irrational attachment to the base choices.
Clint Simpson said:Couldn't someone just buy a Stanley Wonderbar II and cut it down to size?
Hmmm, I am going to assume you are speaking specifically about the base choices in this case. An attachment to these base choices is not necessarily irrational. Dictionary.com defines 'irrational' as "affected by loss of usual or normal mental clarity; incoherent, as from shock" and "marked by a lack of accord with reason or sound judgment: an irrational dislike". Given these definitions, I don't believe that an attachment to either S30V or titanium is irrational. In fact, S30V is one of the better steels out there and titanium is a great metal with some excellent properties. When I originally posted, I was wondering specifically about those 2 materials, since they are the 2 materials being offered. This brings us to the second point.unless as noted there is an irrational attachment to the base choices
I think that, to an extent, you are right. If a piece is truly "custom", not only "handmade", then basically every aspect of the piece should be dictated by the customer. The use of the word "custom" lends itself to certain misunderstandings in the knife world. However, I disagree with your belief that all custom pieces should contain any option that the purchaser wants. This simply would not be possible, as there's probably not a person alive who can add any or every conceivable feature to a knife/tool. Our own humanity limits our abilities. In a word, none of us are perfect and capable of everything. IMO, to expect any given maker to add whatever option the customer desires is not reasonable. Not all makers can do certain things with their materials. Other makers are just very, very busy. yet other makers may not be sufficiently experienced with X materiial.It is a custom piece, any option should be immediate
Trout Tamer said:In fact, S30V is one of the better steels out there and titanium is a great metal with some excellent properties.
Trout Tamer said:However, I disagree with your belief that all custom pieces should contain any option that the purchaser wants. This simply would not be possible, as there's probably not a person alive who can add any or every conceivable feature to a knife/tool. Our own humanity limits our abilities. In a word, none of us are perfect and capable of everything. IMO, to expect any given maker to add whatever option the customer desires is not reasonable. [.........]
In terms of requesting specific steel, I agree that it is a good idea, especially if the knife has a particular intended purpose and a certain steel type will optimize its capabilities. However, I don't think it's wholly reasonable to expect any maker to be able to work all possible steels.
martin j said:Platinum is also great material with some excellent properties, would you want a prybar in this material? Of course not because it is not optimal for prybar. Obviously this is extreme example, however the point is simply S30V is not nearly optimal either. Simply put a cheaper stainless steel like 420 (put aside non stainless carbon for moment) would give BETTER performance even if it were same price and not cheaper.
This argument by you and others is disengenuous, no one saying it should be available in 50 (or even 5) differnt materials, only saying it should be available in more logical/ optimal meterial ESPECIALLY if that material is cheaper, easier to work with, & widely available.
Another way to put it- why should a maker go out of his way to make prybar tool out of S30v???? It is rarer, more expensiv, harder to grind, heat treat & finish then simple 420........ and in the end it performs poorer. OK maybe at this level of torquing etc it won't make a difference........ which raises agin obvious question, why go to trouble of using more expensive, less available and more difficault material for no gain in performance???
No, just in general, though obviously it applies here as well. It is irrational to limit yourself to base choices on a *CUSTOM* piece simply because they are the default choices.Trout Tamer said:...specifically about the base choices in this case.
The statement "one of the better steels" illustrates exactly the point I was making in the above, S30V is a fine steel for some applications, horrible for others, same for Ti, same for any other blade material.In fact, S30V is one of the better steels out there and titanium is a great metal with some excellent properties.
The materials I listed are common *PRODUCTION* steels with well known heat treatments, I can't imagine a maker saying they don't have the knowledge or ability to make a piece out of plain carbon steel or AISI 420.I don't think it's wholly reasonable to expect any maker to be able to work all possible steels.
Shann said:Here's a great idea for you. Don't buy one. Problem solved. Peter Atwood makes great stuff; if its not for you don't buy it.
Can you imagine a knifemaker saying they won't do it because they don't want to make it in one of those types of steels?I can't imagine a maker saying they don't have the knowledge or ability to make a piece out of plain carbon steel or AISI 420.
Cliff Stamp said:No, just in general, though obviously it applies here as well. It is irrational to limit yourself to base choices on a *CUSTOM* piece simply because they are the default choices.
Cliff Stamp said:As noted I don't even limit myself to the steels the maker has worked with, or even any maker has worked with before. This is one of the primary reasons to go custom. It isn't difficult to find makers who will do this, I have no doubt that lots won't though, in fact many don't even do their own heat treating.
The statement "one of the better steels" illustrates exactly the point I was making in the above, S30V is a fine steel for some applications, horrible for others, same for Ti, same for any other blade material..
Cliff Stamp said:The materials I listed are common *PRODUCTION* steels with well known heat treatments, I can't imagine a maker saying they don't have the knowledge or ability to make a piece out of plain carbon steel or AISI 420.
This is again not some kind of irrational faith based decision. If a maker refused to work with a steel when I had from my point of view a sensible arguement for that steel I would discuss it with them, as noted in the above. This provides the chance to learn for both of us as one of us is obviously missing something.Kohai999 said:The maker is not saying that he CANNOT do other materials, he is saying that he is not interested in doing so. If a maker gives you that response, after some mild query as to why, take your business down the road to the next guy, if you want it that bad.
Yeah I do, its my knife after all, so a custom pieces gets made how I want it, that is the main reason why I would go custom in the first place. Of course with any such issue you listen to the maker and don't go in with your ideas without the possibility of change.If you think that as a customer you get to dictate to a maker...
