- Oct 17, 2007
I'd be interested in seeing some pictures.
I thought it was fairly well understood that the KMG came unassembled and unpainted.
As for holes not lining up, I believe that there is going to be a "reveal" of sorts for the tool arm receiver, just based on the finished dimensions of the pieces vs the dimensions of the tool arm, including clearances, etc... It'd be nice if these lined up perfecly, but based on how these are machined, it'd probably cost quite a bit more and require a much more complex process.
Does the tool arm at least fit into the socket?
As the the deburring, unfortunately that all takes extra time and passes on the CNC as well. You should be able to get a de-burring tool from any local hardware for not a lot of money. A few quick swipes here and there should take most of the burrs off. A small file or a sanding block will cover the rest.
At the end of the day, it all comes down to extra time and extra money if you're looking for a more polished, "turn key" machine. Hench the extra $1000+ for the TW-90 I suppose.
