You as an engineer should know that this is not a statistically valid sample
I can try. It's a shadow pattern based loosely on their serpentine stock knife. Although shadow pattern stock knives do exist, they aren't particularly common. The two blades operate on a single spring which makes the knife thinner than a 3-blade. Typically a 2-blade would have a spey secondary. The combination of a clip and sheepfoot is uncommon. But many, including myself, prefer a straight edge blade instead of a spey and there aren't many of those around. Now there are a handful of 2-blade stock knives with a similar combination of blades. But it's not nearly as common as clip blade and spey blade. And I can't think of any at all that are shadow patterns.
I have a hard time understanding why 1-blade knives are so popular on the forum. I suspect it might have something to do with people being familiar with modern tactical-type folders which are typically 1-blade knives. Now I do like single blade knives for some jobs, but I prefer a multi-blade for regular everyday use. In my opinion, the 1-blade traditional knives are the simplest and have the least amount of engineering. If you're making your 1st knife, you'd make a 1-blade. To me, it seems there is a lot more utility in a knife with at least two different types of blades like a clip blade and a sheepfoot (the proposal from CSC). A clip blade and spey blade both have belly. One just isn't as pointy. A clip blade and sheepfoot is not as redundant.
For me, the forum knife is particularly interesting because it's an opportunity to come up with something that is not already readily available. The knife proposed by CSC is the most interesting to me for this reason. Just putting the Bladeforums stamp on a pattern that is readily available is not particularly interesting to me.
Thin in the pocket, but with a full size handle and with the two most useful blades you will ever find.
Canal Street's proposal has no bolsters (Barehead), and fancy wood handles.
Option: We can have a different shield if we choose this knife.
Charlie,
In the past you have given specific instructions
Only take the poll only if you intend to buy
Does this still hold?
thanks for all the work
I'll try and answer this. If Charlie disagrees I'll edit.
Common sense and fair play tells me that if you think you might buy one or the other of these, please vote. If at the time of order you don't have the funds, don't worry about it. A vote here doesn't lock you into the purchase.
If you have no interest in and no intention of buying the Traditional Forum knife, please don't vote.
Unfortunately or fortunately the software only let's you vote once.If I buy 3 knives, do I get 3 votes? [emoji12]
