james terrio
Sharpest Knife in the Light Socket
- Apr 15, 2010
Vanadis 4E has the advantage of the finer powder granules.
CPM 4V has the advantage of being available to buy.
That looks like one HECK of an advantage.![]()
No kidding
Do you mean they are similar or the same steel?
It is my understanding that CPM-4V is a steel from Crucible, and Vanadis 4 Extra comes from Böhler-Uddeholm.
There is a tendency for CPM M4 to work harden in the very thin geometry of a knife blade. Blade sports competitors push the limits and some of these very thin blades work harden and fracture or crack after a year or two on competition, and are replaced. Personally I used 52100 clad with 15N 20 for several years, and the knife is still undamaged. For large blades I prefer high Carbon to stainless or high speed steel. I like to think that my blades will outlive me.
There are many special purpose steels that will give exceptional life with light cutting tasks. Many of these steels will be used and do well in folding knives, it depends on what you like in your knife...Tke Care...Ed
Jose Diazs and I get our 52100 from Kelly Couples. I have lost his contact info but I will ask Jose for it.
Dan
So I'm getting ready to order some 52100 steel for my chopper. I notice that a lot of the handles have a good amount of angle built into them. I imagine that in order to achieve this I would need a 3in wide piece. Would it need to be larger?
I'd like to make something similar to Dan's competition cutter or Jose Diazs' Cane Toad Chopper. I will probably go with 5/16in thick stock too. I've been looking for 52100 steel in these dimensions(3in wide, 5/16in thick, and 15in long), but haven't had any luck finding any. I've looked at NJ Steel Baron, USA Knifemaker, and Jantz and they don't have any. Does anyone know where I could find a reasonably priced slab like this?
If you have a torch, or a forge, you could just heat the tang and bend it to where it needs to be. Even a small plumbers torch will work, but on thicker steel, you might need an acetaline fuel rather than propane.
Maybe try Southern Tool Steel.
Angle = geometry... SO by that logic the geometry of a knife is irrelevant ?? I sure hope i misunderstand him.
I doubt that's what he meant. Perhaps he was just saying that obsessing over a percentage of a degree of angle isn't very productive - that's my opinion anyway. Of course others feel differently... there are cats in MT&E who spend hours and hours comparing a 5-degree .002" edge to a 5.5-degree .003" one and vice-versa.
Overall geometry and whether or not the knife can take the beating you dish out is what probably matters most, followed closely by weight and balance. All those factors work together in any knife, large or small.
You'll find that some of these comp guys don't sharpen their knives exactly the same all the way down the blade anyway. It may be a good deal thinner and more acute near the tip for fine cuts than it is near the middle or heel for chopping. That pretty much throws math formulas out the window.
Something as specialized as a comp cutter seems a lot like a high-end guitar to me. I can buy an exact replica of Tony Iommi's favorite axe, but that doesn't mean it's going to be comfortable for me or make me sound like him.
It's awesome to have guidelines from experienced cutters and makers, but at some point you just have to work with your knife in your hand and see what happens. If the edge doesn't cut well enough, thin it out some. If it's weak, thicken it back.![]()
