Got #130. I think it looks great, G-10, coated blade, Ltd. Ed mark and all. The 710 design is not a "flavor of the month" -- it's timeless. Those who truly appreciate it should have jumped at an M4 version, regardless of the details like coating or markings. If I was one of those who changed his mind, I'd be seriously regreting it about now.
I like everything about this knife, ...
I went over the company's forum and looked around. The backspacer issue is the norm, apparently. Looks like getting an off center blade is not the norm, although someone else reported this.
I emailed Roger and he suggested that I send the knife into BM if I want them to try to adjust the blade centering.
Try adjusting the pivot screw. On some 710's, the female side isn't seated properly. Tighten pivot screw until it's snug (but not too tight. A good test is that the blade will be very difficult to open). Then back-off on the pivot screw until you have your desired opening tension. It should be a little stiff on opening, with no lateral blade play.
In an Axis lock, there's no lateral pressure on the blade, nor are the handle screws important in the blade's lateral tension, so if it's off center, it's usually a pivot screw issue, an off-centered pivot hole in the frame or (very rarely) a bent blade.
-dan
