BM axis lock is better than anything spydy has produced
I hear a lot about the axis lock's omega springs breaking, but I've never heard of Spyderco's ball bearing lock failing. I'd say that beats the axis.
Give it time.
The original Ball Bearing lock (as in the Dodo) and the newer CBL will jam up due to fine particle debrie. The original was worse in this regard.
Spyderco has been in business for years and I have NEVER heard of a single incident where the placement of their deployment hole has caused early deterioration of the blade.
Some what of an ignorant statement.
Glad to see you are gettin' a millie :thumbup:
Why is the BBL any more susceptible to this than the axis?
I guess we'll give it some more time. I don't know which Spyderco introduced the BBL, but the Dodo has been around since 2003. I guess they last at least that long.
POST 103 http://www.bladeforums.com/forums/showthread.php?t=670718&page=6
SoCalJok3r - You are correct that a hole in a blade will weaken the blade, since blades are no different than any other structure known to man. And, bigger holes make weaker structures. I guess some people seem to think a spider symbol on a blade creates some magical affect.
Thx, I didn't know this. I wonder why it took so long for an expert to come forward and reveal this information, but at last there it is.BM axis lock is better than anything spydy has produced
Dig the sarcasm, thanks for the link! Sad day for that spyderco. Also saw on post #20 that you used it to PRY causing it's imminent snap. I mean a knife is for cutting right? Just as you stated "Snapping blades is simple to do ", all you have to do is pry/lever.
Use the right tool for the right job. :thumbup:
I feel that they all have their niche. BM and Spyderco are neck and neck; depends most on which is your style. Generally I feel Spyderco puts out far better small knives (3in and below) while BM puts out far better large ones (4in and above). In between they are nearly the same.
As examples, I'd quote the Dragonfly, Kiwi/Kopa, Cricket, Caly from Spyderco as well as the Skirmish and 610 from Benchmade.
SoCalJok3r, I understand where you are coming from: I just had a brand new Spyderco Manix 2 CTS-XHP break on me, right at the hole while I was cutting some ginger bread.
True that the knife was used for the wrong purposes, but it still does say that the blade is weaker at the hole.
Agreed.
Is it just me, or does it seem like BM intentionally discontinues their great models? I seriously can't believe that the Skirmish, 610, Ares, and AFCK, and 42 didn't sell well enough.
i have no problem with the hole, it makes opening way easier.. i just want your thought on why u feel that particular knife is better than the others.. what knife is better than the BM 950 or even the BM 520? none!! for the price..
like what makes you like spydy more than benchmade or zero tolerance?
