What was the test that led to this conclusion?I can harvest more wood with a folding saw and a large fixed blade, than you can with just a axe/hatchet alone. If I can’t baton with a knife, then it’s no good for me. Take this for what you think it’s worth.
No idea what you’re talking about.Batoning is much safer than using an axe or hatchet. Just ask EngrSorenson .
My own personal tests. I used to be an axe and hatchet guy long ago. Many Gransfors, Collin’s and Hultafors in the stable. I had a close call and almost chopped my lower leg off. I remembered seeing my dad baton big wood into little wood when I was a kid and decided to take that route. A Silky big boy can cut more log sections than your axe can at a much faster rate. Then, it’s just a matter of batoning those rounds down into kindling. Much more wood in a much safer manner. Ask @EngrSorenson.What was the test that led to this conclusion?
Is there a video of this to compare the technique to using an axe?My own personal tests. I used to be an axe and hatchet guy long ago. Many Gransfors, Collin’s and Hultafors in the stable. I had a close call and almost chopped my lower leg off. I remembered seeing my dad baton big wood into little wood when I was a kid and decided to take that route. A Silky big boy can cut more log sections than your axe can at a much faster rate. Then, it’s just a matter of batoning those rounds down into kindling. Much more wood in a much safer manner. Ask @EngrSorenson.
it's a call for an engineering battle, obviouslyI’m not sure what your point is.
No video. Just many many years of personal backpacking/camping experience in the remote woods of Alabama.Is there a video of this to compare the technique to using an axe?
I just carry my wood with me.Much more wood in a much safer manner. Ask EngrSorenson .
How jimping is cut matters. Rounded valleys vs V valleys, the V will cause a crack and it will have a catastrophic failure when it goes. It's ok to have jimping, just properly machined or cut jimpingand yet ESEE's have jimping and a finger choil and can withstand beatings.
It's possible to design a knife that incorporates stress risers that is still robust enough for OP's needs.
In fact... to your point about bridges... that's why engineers design to a "factor of safety". do the math that meets the needs, then overbuild 3x what you needed.
Only if you are completely inept and incompetent with no eye / hand co-ordination......Batoning is much safer than using an axe or hatchet.
That’s true, but any jimping introduces a radius which represents a stress concentration. The bigger the radius, the lower the concentration, but it’s still there.How jimping is cut matters. Rounded valleys vs V valleys, the V will cause a crack and it will have a catastrophic failure when it goes. It's one to have jimping, just properly machined or cut jimping
Accidents can happen to anyone, even grammatical ones. Nobody is incompetent or inept here, just a different way to accomplish the same thing.Only if you are completely inept and incompetent with no eye / hand co-ordination......
It was quite a bit, but we get some every year to keep a good stock of.Damn...that's a fatwood motherlode right there. Last you for decades, your grandkids as well... What a harvest! Brave to baton that as well.
When we cut 12560 armor into parts that go on strykers and tanks, there's radiused features. A proper transition when changing angles is the difference between a part that fails when you need it most and one that lasts a lifetime. Spreading the stress vs concentrating it. Works for vehicles that run over ieds and take rpg hitsThat’s true, but any jimping introduces a radius which represents a stress concentration. The bigger the radius, the lower the concentration, but it’s still there.
I can't attest to this in its entirety, but what I can say is that high hard (46100 armor) and 12560 are hardened before we machine them.I've read...........When, jimping is cut matters too
Bruh. Your fatwood rich! Mail me a chunk
